91 Camry Exec installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2004, 12:53 AM   #1 (permalink)
View jethroyau's Photo Gallery
G'day All.
I'd just recently purchased a new Cd player for my 91 camry. Thing is, I have no idea how to remove the old stock radio. I tried pulling out the plastic molding that covers the radio/air con part of the dash, but toi no avail. I can't see any screws either. Are there any sites out their that can help me? I tried http://www.carstereohelp.com/stereoremovalToyCamry3.htm
but it seems like the US Camrys are different? Cos I can't seem to find the screws mentioned in the guide...
Any help would be much appreciated. BTW, I want to replace the stock 4" front speakers in the dash - is it really hard to DIY or should I pay a shop to install it? Must I use another 4" or can I put a bigger one in?
jethroyau is offline   Reply With Quote
Old 10-31-2004, 01:01 AM   #2 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
Hmmm I'm not sure why your screws would be in a different spot... But there are 2 screws at the top of the molding that are in recesed holes at a 45degree angle upward, in all the gen2 Cam's I've seen.
As far as replacing your speakers, I don't think it's all that hard. Done it a couple of times, and if you are somewhat mechanicly inclined, it should be fairly easy.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 10-31-2004, 01:02 AM   #3 (permalink)
So do I have to remove anything to see the screws? and they are above the A/C part of the dash?
Old 10-31-2004, 01:06 AM   #4 (permalink)
Not so Noob now!
es250nut's Avatar
The screws will be right above the climate control. Otherwise the rest of it is held in by clips. You will want to have your shifter in the far back position so your ash tray portion will have clearance. Also watch the connector to the 12V power plug/cig lighter.
Old 10-31-2004, 04:48 AM   #5 (permalink)
Well, after fiddling with it more, I managed to remove the damn plastic molding - there were NO screws above the A/C console. It was all clipped on. Actually, there was one screw I needed to remove - it was located under the demister button. Funny, I think this is probably being our Aussie Camry's are homemade in Australia hence the slightly different layout??
Old 10-31-2004, 09:42 AM   #6 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
just to let ya know
the dash speakers in a gen2 are 3 1/2" not 4".
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 10-31-2004, 11:02 AM   #7 (permalink)
View drugal's Photo Gallery
You can mount 4" dash speakers on the Canadian Gen2, which is probably the same as an Austrailian model.
They have holes to mount 4" speakers or the speaker boxes that contained the 3.5".
I don't know about the American model, but I'll be finding out today as I install my sound system from my previous car into my new one.
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Old 10-31-2004, 05:03 PM   #8 (permalink)
Luc
View Luc's Photo Gallery
U.S. models are the same deal with the front speakers.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 10-31-2004, 06:13 PM   #9 (permalink)
Working hard?
View noofa's Photo Gallery
I put 4 inch in the other day, was not hard, just find all the screws in the dash get some connectors for the stock wiring, it goes ok and makes it that much easier btw use the open socket bits on the speakers i had kenwood and they only just fit. you should try the passenger side first, its much easier. when i changed tuners i pulled the entire lower dash apart, it worked and wasnt that hard to re assemble, didnt have a single screw left over!
Rep'in Team Hamster In OZ
Need power? Get an Ebay Intake mod!!!
***MOD: Signature violation. Size is too big. Keep it under 500x150 pixels.***
noofa is offline   Reply With Quote
Old 10-31-2004, 08:10 PM   #10 (permalink)
Ok, I was going to install some Pioneer 4" speakers...but I am getting different opinions left right and centre. some people say that Camry air duct's gonna be in the way since the magnet's too big. Others say it'll fit fine. Who should I believe? I don't wanna buy the speakers, open em, and find that they don't fit...
Old 10-31-2004, 08:24 PM   #11 (permalink)
Working hard?
the only way to be sure is to check it for yourself. Remove the underdash section and take a look for yourself. The stock speaker i have right here and its 45mm from front to back and my kenwood 4 inchers are 42mm thick and are 90watts. The specs should be on the box, if you havent bought them check the website.
Dimensions
Mounting Depth 43mm
Dimensions 134 (diam.) x 62mm
Weight 840g per pair
Carton 323 x 75 x 152mm (WxHxD)
Carton Weight 950 g
Taken From
Old 10-31-2004, 08:31 PM   #12 (permalink)
Straight from Pioneer's site:
Mounting Depth 43mm
Dimensions 134 (diam.) x 61mm
sounds like it should fit. Hopefully they'll sound better then the stock ones.
I have another problem - I bought these Sony 6" speakers but only just found out there are no mounts in the rear (its a wagon). Where do I get speaker mounts? wreckers? is it going to be a pain to install or should I get em fitted @ a shop?
Old 10-31-2004, 08:32 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The front speakers fit inside a enclosure.
So the only way they won't fit is if their to big or to deep.
See thread for pics:
'89 Camry Speaker Install
Car stereo shop or make your own out of mdf, plywood, etc...
"Skoolin' the unlearned!"
Old 10-31-2004, 09:02 PM   #14 (permalink)
Working hard?
jethroyau PM replied
Has anyone got pics of their own install, (the inside of the dash) 88 LE's link showd somthing totaly different to what my 91 has???
Old 11-01-2004, 11:58 PM   #15 (permalink)
After a weekend of trying to move my sound system from my old Gen2 into the new one, I found some info that might help out some people, for what it's worth:
The US Gen2's dash pieces are totally different from the Austrailian/Canadian/Rest of the World/etc.. Gen2s. They're also a #$%&ing PITA to take apart.
The US Gen2 has those boxes for the speakers, which hold a 3.5" speaker. It has no provisions for a 4" speaker, which is dissapointing.
The rest of the Gen2s can hold that speaker housing, and some actually came with it, but they also came with cheap 4" speakers as well, which screw directly onto the dash piece.
So, to sum it up:
US Gen2: 3.5" only
Other Gen2: 3.5" with housing or 4" stand-alone.
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
