gen 3 subwoofers? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2004, 09:00 PM   #1 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
gen 3 subwoofers?
has anyone ever tried putting subs on the backseats of a gen 3? If you move the back seats down their is a cut hole for easy access to the trunk.. has anyone every mounted subs there?? does anyone have any ideas on quality of sound
vsixcamry is offline   Reply With Quote
Old 11-01-2004, 09:04 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
You could. I just put my 10" kickers in boxes in the trunk. There isn't a decible differance with that passthrough open or closed anyways.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 11-01-2004, 09:10 PM   #3 (permalink)
toyota tuner
vsixcamry's Avatar
im gonna try it...i need to buy my amp first... and i am hoping 10s will fit cause i dont feel like buying 12s (trying to save for turbo)
Old 11-01-2004, 09:49 PM   #4 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
12s would be too big 10s fit though.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 11-02-2004, 01:28 PM   #5 (permalink)
View yotacam98's Photo Gallery
My buddy did a Free Air setup in his gen 3 (now wrecked)
If you dont know, that is when you mount some type of baffle board where the back seats are (you can build to fit behind seat or take up where the back seat was) I think he used 1 1/2" high density fiberboard, carpeted it, modified and cut the pass through seatback/trunk opening to accomadate 2 12s and 2 tweets, sealed up the entire trunk with sound deadening material (like dynamat) you are now using your entire trunk as a speakerbox.
It should be noted though that only certain subs are suitable for this type of application, (check mfg. specs) for example, Pioneer makes a free air sub which handles a little more power and is less sensitive w/ a slightly differnt basket design. 2 of those in his cam pounded hard.
98' Camry LE (5SFE) w/ a slushbox
K&N,Denso,Hypervoltage
yotacam98 is offline   Reply With Quote
Old 11-02-2004, 03:37 PM   #6 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
Just finished building a box for this, below are the dimensions and plans for mine. Not drawn to scale, but I included measurements. It worked for me, and I'm happy with the results. So don't sue me if you use it and don't get what you're looking for.
And I'll go ahead and warn you that if you use this plan, nothing is square. You're gonna have to do some custom work, these are just the dimensions of my final product.
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
Old 11-03-2004, 12:16 PM   #7 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
that enclosure seems to be too small for two tens, what subs are they?
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 11-04-2004, 06:02 PM   #8 (permalink)
toyota tuner
vsixcamry's Avatar
do any of you know where a good place to connect my amp to the battery is in a gen 3?
Old 11-05-2004, 07:43 PM   #9 (permalink)
Toysrme's Avatar
Cool
Jesus that is a shallow box.
Now with Turbo!
Old 11-06-2004, 12:48 AM   #10 (permalink)
View finese1's Photo Gallery
That is a small box. But it also depends on the sub. And to Vsixcamry i had two tens on the back seat and 2 twelve in the trunk. You feel a lot of punch and of course but I wouldn't base my sub on the back seat
finese1 is offline   Reply With Quote
Old 11-06-2004, 11:49 AM   #11 (permalink)
toyota tuner
vsixcamry's Avatar
what if i were to set the subs back like a foot and build a box around the back, so they will still face the seats but will be set back???
