I have an mtx 8000 12". It has a two inch tear on the surround. I am thinking about using the sub for my girlfriend's car. First, will it sound all that bad?
I played it, IB, from a PG ti400 I have and honestly it sounded pretty good. I could hear a little flapping sound, but nothing too bad.
My second question is, can this be fixed by me. I was thinking about sewing it closed with some 4lb test spiderwire and then using silicon caulk? Any ideas. Also, if I did install it, I would want to go sealed,but with the hole in the surround, it would ovbiously not be sealed. would this really screw the sound?
any ideas or even just experience with torn surrounds would be appriciated
Peace cannot be kept by force, it can only be achieved through understaning. - Al Einstein
just glue the tear using rubber cement of something similar... i doubt the tear will make an audible sound difference since its mostly the cone that moves the air and makes the sound
1995 Silverleaf Metallic Camry LE Automatic beater
Thanks, I really like the way the Polk/MOMOs look, they're nice and clean and you can remove the end caps so you can put them side by side to look like a really long amp. My only complain is that I wish they put out more power, but that's only because I'm crazy. Their power is already pretty underrated.
i've repaired several tears in sub surrounds. Use some flexible silicone and you'll get the best results. If its the part that is glued to the basket (metal frame) then you can use whatever will hold it best. I used some type of appliance glue that worked really well.
With sealed boxes, the hole Will affect the sound. And since its a 'moving' part, Its likely you'll hear it. So glue that baby down and stick some foam inside the box. I've found that the better the seal, the better, and more solid the sound.
What kind of surround material is it? I've taken my speakers to a speaker repair shop to fix. They'll do surrounds, cones, etc... Look in your local Yellow Pages for a shop.
