protection mode - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2004, 02:53 PM   #1 (permalink)
View MYCARcamry's Photo Gallery
protection mode
how long does it take a amp to get off of proctection mode?
MYCARcamry is offline   Reply With Quote
Old 11-02-2004, 06:27 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
well depends on whats making it go into protection mode. if you have your subs hooked up at too low of an impedence it will most likely go into protection mode right away... if its overheating it will just wait till it drops below a certain temperature... I think the main problem you need to find out is what is causing the amp to go into protect mode.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 11-02-2004, 06:35 PM   #3 (permalink)
i believe because of a low ohm
Old 11-02-2004, 06:36 PM   #4 (permalink)
i was trying to run 4ohms bridge onto 2 dual 4 ohm subs i followed a diagram that showed me how to wire it up but as soon as i turn on my sustem the amp just shut down
Old 11-02-2004, 06:40 PM   #5 (permalink)
the amp i have is the kenwood kac-7201 would this amp go into protection or am i screwed and i have to toss it?
Old 11-03-2004, 12:11 PM   #6 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
so let me get this right, you have a 2 channel amp and your are trying to hook up two subs that are dual 4 ohm each? If that is the case, you wire it wrong, because you should have no problem with this config.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 11-03-2004, 06:08 PM   #7 (permalink)
everything is cool now i blew a fuse the fuse i blew was a 50 amp fuse i cant find it anywherre so i replaced it with a 60 amp is this ok?
Old 11-03-2004, 11:06 PM   #8 (permalink)
Got SQ?
eddiem67's Avatar
what is the recommended fuse for your amp, you should use that
Gen 4 V6
