Pull sail panel off, remove two screws at the bottom of the door panel, remove one screw at door jam, remove two screws in the arm rest, they are covered, you will need a flat head screw driver to remove covers, there should be a little round cover at the middle front end of the door panel, remove that and unscrew the screw, at the door latch there is a little square behind the latch, use a flat head to open it and unscrew the screw, remove the the plastic bezel for the door latch. With a flat head screwdriver gently pry out control panel in are rest, disconnect the harness from the control panel. You should have a total of 7 screws, a bezel, a control panel, and a sail panel, now your ready to remove the door panel. Start at the bottom and pull gently out, then slide door panel upward.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
