finding the closest battery access - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2004, 06:04 PM   #1 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
I am looking for the easiest way to connect my amp to the positive wire of my battery... or do i have to run a wire all the way to the battery? I have a gen3 camry and the subs are 300 watt.
vsixcamry is offline   Reply With Quote
Old 11-04-2004, 06:18 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Australia
The only proper way to run an amp is to run a power wire from the amp to the battery DIRECTLY.
This is beacuse the fuse ratings and wire guages are not usually up to the task of running hi powered amps.
So, for 300w system power, you would simply run 8GA power wire to the battery by removing trims and panels to make it neat. Thru the firewall, and then to a FUSE. You MUST run a fuse close to the battery as this will protect your amp and your car in the event there is a short. Then just connect the power wire to the battery with an eyelit connector or something.
The earth can be located anywhere close to the amp, screwed or bolted to a metal part of the car. I chose the seatbelt bolts.
If you plan to run high powered amps in the future, or 2 or 3 amps, i would run 4GA wire and use a distribution block to seperate it into 2 or 3 8GA wires, depending on how many amps you have.
Anymore questions...just ask.
Thanx.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-04-2004, 06:32 PM   #3 (permalink)
toyota tuner
vsixcamry's Avatar
what type of fuse whould i use?
Old 11-04-2004, 06:47 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ In line fuse holder with a AGU type fuse.
Or a circuit breaker.
http://knukonceptz.com/productMaster...Fuse%20Holders
https://www.delcity.net/tstore/servl...=193073&page=1
"Skoolin' the unlearned!"
Old 11-04-2004, 06:50 PM   #5 (permalink)
toyota tuner
vsixcamry's Avatar
thanks... a fuse holder can hold any kind of fuse?
Old 11-04-2004, 06:56 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
^ No.
Look at the first link I posted above.
The fuse you use depends on the fuse holder (agu or anl).
Fuses:
http://knukonceptz.com/productMaster.cfm?Category=Fuses
Old 11-04-2004, 09:36 PM   #7 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
no need to use an ANL fuse holder on anything less than 100 amperes, use an AGU, they're the most common anyway
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
