Originally posted by eddiem67
put in a 30 amp fuse if this is the only amp you have, and why in the hell this you buy such a big wiring kit, an 8awg kit would be suffice.
Because it has everything I need except a big fuse
, other small one only has one RCAs cables.
4-8 ga. power distribution block
MAXI in-line fuse holder with 100 amp fuse
14 ft.,5 ga power cable
6 ft., 9 ga. power cable
4 ft., 9 ga. ground cable
17 ft. blue remote wire
Two 17 ft. clear audio cables
platinum finish connectors
All necessary hardware
I will go to get smaller fuse for it.
Thanks,
