Wires for remote starter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2004, 01:11 PM   #1 (permalink)
View nicgravel's Photo Gallery
Hi !
I want to know which wires is to connect a remote starter on a Camry 1991. No power windows, automatic.
If you can be clear on the color and where to find the wire..specialy for tha tach.....
Thanks a lot
(it's for a remote starter Nordicstart NS-1003)
regards,
Nick
nicgravel is offline   Reply With Quote
Old 11-13-2004, 12:03 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
Here ya go.
Source: wire colors, polarity, location
12volts: white or white/red, +, ignition harness
Starter: black/white, +, ignition harness
Ignition: black/yellow, +, ignition harness
Second Ignition: black/orange, +, ignition harness
Accessory: pink/blue, +, ignition harness
Power Lock: lt.green, -, either kick panel
Power Unlock: green/red, -, either kick panel
Parking Lights+: dk. green, drivers kick panel
Notes: Located in a clear plug with about 15 wires just below the fuses in the fusebox
Parking Lights-: green, steering column
Door Trigger: red/white, -, drivers kick panel
Trunk/Hatch Pin: red/white, -, light or sw in trunk
Notes: Common with doors in wagon.
Tachometer: black, AC, ignitor, diagn. plug
Notes: must go to the ignitor on 4 cylinder versions.
Brake Wire: green/white, +, at brake pedal switch
Horn Trigger: green/black, -, steering column
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
