remote in??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2004, 03:47 PM   #1 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
Question ------ remote in???
i bought a streetwires wiring kit to hook my amp to my batt. and head unit. The wire it provided goes into the "remote in" of my head unit. I have a sony xplod head unit and i have no idea where that input is..... what does the remote wire do? is it important?
also...does the amp get plugged into the rear speakers (rca)output of the headunit?
thanks for your help im nearing the completion...
vsixcamry is offline   Reply With Quote
Old 11-13-2004, 05:37 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: remote in???
There should be a blue wire coming out of the deck. Thats the remote turn on lead/wire.
This gets wired to the remote turn on, on the amp.
The purpose of this wire is to turn on the amp or processors (x-over, eq, etc..) whenever the deck is on.
Use the rca outputs.
"Skoolin' the unlearned!"
Old 11-13-2004, 07:33 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
it can also be connected to your antenna wire
HaHa
Old 11-13-2004, 10:30 PM   #4 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
^^^huh, I never thought of that... interesting. Not a big deal for me since my RCA cables have built in remote turn on wires (which is really sweet).
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 11-14-2004, 01:29 AM   #5 (permalink)
View ZXLNT's Photo Gallery
If you connect to the power antenna lead it may not turn on the amps when your HU is in CD mode. Lots of radios don't power the antenna remote when your playing a CD. Make sure you use the regular remote out..
Boston!! 100 Percent Guitar Driven Rock and Roll
99 Solara SLE 1MZFE
ZXLNT is offline   Reply With Quote
Old 11-14-2004, 02:41 PM   #6 (permalink)
TN Pussy Man
^ true....but from what I've seen, most aftermarket decks are lazy and they always make the antenna go up.....
but if you have a romote out, then use it for sure
HaHa
Old 11-16-2004, 09:47 AM   #7 (permalink)
toyota tuner
vsixcamry's Avatar
theyre is a large coupling of wires...and an input labeled remote in.....which one is the remote in (the input, or a blue wire in the large coupling of wires)???
Old 11-27-2004, 11:48 PM   #8 (permalink)
toyota tuner
vsixcamry's Avatar
keep it fresh...
Old 12-01-2004, 09:07 PM   #9 (permalink)
toyota tuner
vsixcamry's Avatar
anyone know????
Old 12-02-2004, 01:00 AM   #10 (permalink)
TN Pussy Man
^ should be the blue wire then....
where it says remote in, it should be connected to your remote out (if oyu have it on your deck) and if not, then your antenna signal wire (the one that just tells it to go up, not the actual power wire)
HaHa
Old 01-08-2005, 05:39 PM   #11 (permalink)
toyota tuner
vsixcamry's Avatar
i see a wireing harness with a blue wire then an input for a plug ( like headphone plug size, pretty small) which one?
i think you are talking about the blue wire within the wiring harness but how do i go about connecting the remote control wire to the amp. do i simply strip the blue wire's insulation and connect??
Old 01-08-2005, 11:44 PM   #12 (permalink)
Street-Cruiser
Ostornadoe's Avatar
View Ostornadoe's Photo Gallery
Just strip and connect yes. The remote wire hookup coming out of the deck should not be a wire going to something, it should have an end that you can find. You could also just put the wire into your fuse box into a fuse that is live when the car is on.
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
Ostornadoe is offline   Reply With Quote
Old 01-09-2005, 11:53 AM   #13 (permalink)
toyota tuner
vsixcamry's Avatar
thanks man, huge help
Old 01-12-2005, 10:48 PM   #14 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
If a HU does not come with the remote wire, then you should use the antenna wire. It doesn't matter if it's in CD mode or what, it will turn it on.
http://www.xclusive.bz
