My amp just shuts off sometimes on me, I don't have the volume up loud, and sometimes all i have to do is turn off then on the head unit. Sometimes that doesn't work tho and I just sit there listening to bassless music until it just magically turns back on. Anyone had/have this problem?
It is currently happening to my rockford 1500bd, I bought a new alternator (150amps), change the wires, moved ground, even lowered gain, and it still does the same thing..
If your subs are bridged you are probably overloading the amp. I'm guessing you are running the subs at 1ohm when you bridged them, and have the amp running at 4ohms. To bridge the rockford I think it is the left - and right +. That will get you 1ohm.
Is the amp hot when it shut off? Did you turn on low pass filter? Feeding high freq to sub is just wasting power. Where the gain setting at the amp? Turn the gain all the way down, set deck at highest volume without distortion, disconnect/turn off all speakers, increase gain to sub until it won't get any louder or start to distort (its kinda hard to tell if its distorting, usually sub won't get as loud after a certain point), turn it back a bit.
