wiring toggle switch for led's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2004, 03:10 PM   #1 (permalink)
toyo man for life
View 97avalonxls's Photo Gallery
I want to add some led's in my airvents and footwells. what is the correct way to wire a toggle, SPST I assume? please post any suggestions, help with wiring instructions. the led's are already resisted and set, they just have positive and neg leads. thanks
Peace cannot be kept by force, it can only be achieved through understaning. - Al Einstein
97avalonxls is offline   Reply With Quote
Old 11-17-2004, 03:44 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
if they're already resistored, then they're ready to go with just a current
its when people don't know that they need resistors that they have problems
HaHa
Old 11-17-2004, 04:01 PM   #3 (permalink)
toyo man for life
well, I still do need advice for the switch. do I just run all the + to one post and all the neg to the other. do I ground the led's to the switch neg, or to the chassis
Old 11-17-2004, 06:42 PM   #4 (permalink)
TN Pussy Man
ahhh....
basically, just ground the leds to the chassis or somewhere, and then splice the power line from somewhere, and run the switch in the middle of the positive wire
the switch will be used just to break the current
if the switch you got also has a negative on it, it's usually just for the led that is installed into the switch, and NOT to be used as a grounding point for the rest of your lights....in fact, it won't work beacuse then nothing would be grounded
HaHa
Old 11-18-2004, 06:01 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
A spst (single pole single throw (2 prong)) switch will work just fine.
Wire all the leds in parallel (positive to positive, negative to negative).
Positive to +12V (constant or switched).
Negative to ground (chassis).
The switch goes in series with the power wire (positive).
Heres a schematic that I drew up:
spdt (single pole double throw) (3 prong)) switch:
If you use a spdt switch. Use the center terminal and one of the outer terminals, like in the pic above.
"Skoolin' the unlearned!"
Old 11-18-2004, 08:42 AM   #6 (permalink)
toyo man for life
thanks for the great post 88, I have no more questions, I will be completing this as well as my bi amping this weekend(still have to figure out how to best create a pass band for my mids). THanks again all, as usual
