Running the Power Cable - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2004, 07:00 PM   #1 (permalink)
View bjeremi's Photo Gallery
I got an 04 Camry LE, does anybody know a good way to run the power cable for the amp without drilling the fire wall. Thanks in advance
My other toy
bjeremi is offline   Reply With Quote
Old 11-21-2004, 07:14 PM   #2 (permalink)
Street-Cruiser
Ostornadoe's Avatar
View Ostornadoe's Photo Gallery
In most cars there is already a hole running through the firewall.... Look near the gas pedal. The radio and all your other interior power wires will be running through it...
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
Ostornadoe is offline   Reply With Quote
Old 11-22-2004, 11:14 PM   #3 (permalink)
Noob in Training
View 96AvalonXLS's Photo Gallery
I ran my 4 gauge through the existing grommet on the passenger side of the firewall. It's at the top of the firewall with an accordian looking boot over the wires. From what I hear the Camry is a similar setup as the Avalon.
Thumping XLS - It's amazing what Phoenix Gold can do for Toyotas.
http://www.cardomain.com/memberpage/717086
96AvalonXLS is offline   Reply With Quote
Old 11-22-2004, 11:37 PM   #4 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
I found no hole on my 02 Camry. So i Made one.
- Vince
VVT-i Owns is offline   Reply With Quote
Old 03-09-2005, 01:08 AM   #5 (permalink)
View 1200mk's Photo Gallery
i have the same question.... and where did you guys mount your fuse holder?
1200mk is offline   Reply With Quote
Old 03-09-2005, 10:36 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Thats where the engine wiring harness goes thru.
I ran mine thru a grommet hidden behind the drivers side fender liner.
Drivers side strut tower, but I have a circuit breaker instead of a fuse holder.
"Skoolin' the unlearned!"
Old 03-09-2005, 10:42 AM   #7 (permalink)
do you have a gen 5? i see no orange gromet on my gen 5
Old 03-09-2005, 10:48 AM   #8 (permalink)
Gameroom cash: $147537
There should be a hole between the firewall and sturt tower. It go into fender and if you remove the plastic cover around the wheel well, you can see there are holes going into the cabinet. Same thing on both sides.
Old 03-09-2005, 11:35 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
I have a gen 2 Camry.
Did you remove the front drivers side fender/wheel well liner?
The grommet in my picture is not in the engine bay.
Old 03-09-2005, 11:43 AM   #10 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
through the grommet by the steering column...just gotta make sure that it won't get tangled. Also...the fuse should be within 18"s of the battery, I did mine on the side of a fuseholder....works for me
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 03-09-2005, 01:25 PM   #11 (permalink)
Unrecognized
DMDrew812's Avatar
View DMDrew812's Photo Gallery
Remember to be keepin that high power cable far from the low power pre-out lines, you can get some nasty sound interference that way.
DMDrew812 is offline   Reply With Quote
Old 03-09-2005, 02:24 PM   #12 (permalink)
Fixing My Jet
Gameroom cash: $101050
View Meperezs's Photo Gallery
http://toyotanation.com/forum/t69285.html
there is another thread on the same topic...
If you can read this thank a teacher. If you can read this in English thank an Airman.
Meperezs is offline   Reply With Quote
