deck wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2004, 07:45 AM   #1 (permalink)
View SammyLJ's Photo Gallery
deck wiring
just a quick question
if i'm wiring up a new deck and i wire the speaker + & - and then decide that I want to use amps to the speakers. Will it matter to the deck if the + & - wires are still hooked up while the front and rear preouts are hooked up or with I have to cut the + & - going to the harness?
SammyLJ is offline   Reply With Quote
Old 11-25-2004, 05:16 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Use one or the other, but not both (speaker outputs & pre-out).
If your going to use a amp, use the pre-outs on the deck. Disconnect the speaker outputs either at the deck or at the speakers.
Then run wiring from the amp to the speakers.
"Skoolin' the unlearned!"
