Adding keyless entry/alarm to 2005 Tacoma? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2004, 11:37 AM   #1 (permalink)
View tacomabenny's Photo Gallery
Hi from a newbie...
I just got a 2005 Tacoma. Regular cab 2X4 which you can pretty much only get with A/C.
Will it be possible to get the manual door locks converted to power as part of an alarm package and thus have keyless entry? I wouldn't be doing this DIY.
Almost as important, though, is should I? Is this a reasonable solution? Warranty issues?
Kind of hard to go from a 1999 A4 to an old-fashioned manual everything...
...but that's what I wanted...
benny
tacomabenny is offline   Reply With Quote
Old 11-25-2004, 11:40 AM   #2 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
Yep its simple to do, all you have to do is install actuators(sp?) up to the door lock relays on an alarm and voa'la pwr door locks.
Hatch is offline   Reply With Quote
Old 11-26-2004, 02:04 PM   #3 (permalink)
Turns out you can't...
at least very easily.
They have changed the door lock system to a cable system.
Nobody seems to know how to do that yet.
Anyone?
Old 11-26-2004, 08:27 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Not quite.
The door lock/unlock outputs on a alarm are low current outputs. Their used to drive a relay which then drives the actuator.
There is no relay on the alarm for door lock/unlock. You need to wire up a external relay.
"Skoolin' the unlearned!"
Old 11-27-2004, 09:06 AM   #5 (permalink)
Hatch's Avatar
Originally Posted by 88 LE
Not quite.
Yeh sorry I should have gone into more detail
Old 11-28-2004, 11:11 AM   #6 (permalink)
The 2005 is different than previous models...
The 2005 does use an actuator but that isn't the preoblem for converting from manual locks.
The actuator is enclosed in a plastic unit and isn't out in the open like other cable drived lock systems (this according to my installer).
None of the kits to-date will work. Bummer as I thought it would be pretty straightforward to get keyless entry added aftermarket to the basic regular cab 2005 Tacoma.
Thoughts?
Old 11-28-2004, 12:37 PM   #7 (permalink)
Hatch's Avatar
The way I see it at my shop is that if the customer wants it we will do it. Unfortunately you are in SanDiego
Old 11-28-2004, 01:26 PM   #8 (permalink)
Thanks Hatch...
...can you let me know if you get inside a 2005 Tacoma regular cab door and maybe give your opinion on how hard it would be?
you can email me if you wish...
