need help with amp!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2004, 03:17 PM   #1 (permalink)
ant
View ant's Photo Gallery
hi, i have a sony xplod amp and when i hook it up it worked good, i then put it in my friends car and voice was coming out from the sub so we put it back in my car. when i hooked up back to my car the amp turns on but there is no sound coming through it, i double check the bridging and the rca cables but stil no sound. any ideas? thanks
ant is offline   Reply With Quote
Old 12-01-2004, 03:24 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
check your subs? try your friend's subs again with the amp to make sure that its not the amp
HaHa
Old 12-01-2004, 05:49 PM   #3 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
you need to set your crossover properly on the hu, and if the hu has a sub preout use that.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 12-02-2004, 01:22 AM   #4 (permalink)
ant
thnx for the help..ill give a try 2m. just to let u know, my hu have 2 output and 1 input. a rear output and front output. i plugged the cable to the rear output which goes to the rear input of my amp.
Old 12-02-2004, 11:57 AM   #5 (permalink)
Got SQ?
eddiem67's Avatar
If you cant set the crossover setting on your HU then you must do it on the amp, there should be a switch for low pass filter, make sure it on and set to around 80Hz
Gen 4 V6
Old 12-04-2004, 01:20 AM   #6 (permalink)
ant
doesnt work..i dunt know wut the model of my sony xplod amp is but it has a built-in equalizer. i think it has something to do with the inputs because tere should be lights scrolling left and right on the equalizer if there is sound going through
Old 12-04-2004, 01:29 AM   #7 (permalink)
Luc
View Luc's Photo Gallery
How can you not know the model of the Sony amp? Has the manufacturer tag been ripped off from under the amp? Did you flip the amp over and check? A bit of your own detective work will let others help you, and not guess about every possibility.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 12-04-2004, 03:55 AM   #8 (permalink)
ant
sorry..
model is XM-604EQX
pic - http://www.cardomain.com/shop/view_l...ku=SONXM604EQX
