home speakers in car...help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2004, 10:16 AM   #1 (permalink)
toyo man for life
View 97avalonxls's Photo Gallery
the home versions of the morel and focal line, speaking of the stuff in Parts Express, is all 8 ohm. I was wondering how some of these speakers will do in the auto environment, I have 4x100 for the tweets and the woofers, so I assume if I bridge the channels, and don't biamp, I could still keep 100 watts going to each speaker. Is this correct.
Could I double the speakers, IE buy two midbass driver for each door and then run them parallel? any disadvantage to this? Does anyone have any thoughts on this matter.
ps I'd be making f/g enclosures for the midbass drivers, so they would not be at all exposed to the elements.
lastly, does anyone have any recommendations from those two lines (morel and focal), either a whole three way setup, or just a real nice midbass driver to augment my polk momos (5.25)
thanks
Peace cannot be kept by force, it can only be achieved through understaning. - Al Einstein
97avalonxls is offline   Reply With Quote
Old 12-02-2004, 10:17 AM   #2 (permalink)
toyo man for life
btw the f/genclosure could be open, sealed or I guess even ported, I don't know how difficult that is though
Old 12-02-2004, 11:54 AM   #3 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
many people build diy component sets, but you still need to build a passive crossover network for the set, running them in parallel will give you the 4ohm load, but the amp is now bridged and will be giving out about 200-300 watts (based on your amp of course) which is fine for you midbass, but not for your tweet.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 12-02-2004, 12:05 PM   #4 (permalink)
toyo man for life
what if I ran the comp set I have, the polk MOMOs only single input, and used the rear channel to run the midbass, I could get 100 watts to every speaker that way, correct? and I would only nee a very basic bass blocker for the midbass, just to keep out the sub 90 level.
the setup would be, midbass, with bass blocker and lowpassed at around 300,
components highpassed at 300 of the amp,
sound workable?
Old 12-02-2004, 12:07 PM   #5 (permalink)
toyo man for life
oh, I would still be running the two midbass in each door in parallel, to keep everything 4 ohm.
Old 12-02-2004, 12:12 PM   #6 (permalink)
Got SQ?
eddiem67's Avatar
that should work fine, have fun tuning...thats is a lot of speakers to work with to get it to sound right. but it IS capable of sounding nice.
Gen 4 V6
Old 12-02-2004, 10:32 PM   #7 (permalink)
Luc
View Luc's Photo Gallery
Home speakers may not be built to endure the weather changes that the car goes through, even though you are in Florida. You should check with Morel or Focal and see if they would recommend it.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 12-03-2004, 09:03 AM   #8 (permalink)
toyo man for life
I think that's probobly a good idea, I know the temperature will not be an issue, I'm only concerned about the humidity(definately a moist climate). my car is pretty well sealed. oh well, I guess I should look more into the kodas, they're 4 ohms and intended for auto use. only problem is the mounting depth, they are a little deep for my doors, at least for my intended design, such is this industry/hobby, all about adaptation.
