amp install problem-help guys, this is weird
installed amp (which is mounted to the chassis/body) - then connected 12v, remote line & ground - turned on ignition and it powered up fine so I connected the rca's to the amp and line output converter(connected to rear speakers) and the speakers "popped" once and the amp lost power... Turns out that the fuse on the 12v line to the battery was blown, bought a new LOC and repeated the process and got the same result... What the heck?? I've contemplated that the chassis mounting of the amp could be the problem but haven't unbolted it to try again yet.
