Amp - American Legays LA960 1200w max - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2004, 10:22 PM   #1 (permalink)
View Beamonesque's Photo Gallery
Amp - American Legacy LA960 1200w max
Anybody know the rms on this thing? I got that powering two 10" 600 w maxQ power subs, in a bandpass plexiglass box. I'm missing two screws on the plexiglass cover so their is an air leak. How much does an air leak worsen the sound/loudness of subs? Just tryin to guesstimate b4 I go out to the 24hour walmart to get some screws tonite?
'90 camry le
Beamonesque is offline   Reply With Quote
Old 12-04-2004, 01:24 AM   #2 (permalink)
Luc
View Luc's Photo Gallery
You need to make sure that plexiglass is secured properly. Air leaks are not good for sound or the subs, especially in a bandpass box. With air leaks, you are defeating the purpose of a box and the subs may "think" they're not working properly, so they could over work, even though I don't think that flea market type amp will give you any real power.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 12-04-2004, 01:55 AM   #3 (permalink)
another bit of info....The amp specs says "2 Ohm Stereo Stable
Bridgeable into 4 Ohms" I have two 4ohm woofers... How would that work? Do I have to bridge it since speakers are 4ohm?
'90 camry le
Old 12-04-2004, 11:00 AM   #4 (permalink)
Luc
2-ohm stereo is equivalent to 4-ohm mono, so you'll have to wire up the subs so the amp will see a 4-ohm mono (bridged) load. Otherwise, the amp will overheat, shut down, and potentially get damaged. If your speakers are 4-ohm each, you can hook it up in a parallel fashion, but that would be a 2-ohm mono, or 1-ohm stereo, which IS NOT good for the amp if it can't handle that load. You'll be damaging the transistors and popping fuses. Either get some subs that are 4-ohm DVC or 8-ohm SVC if you plan on using that amp. Or, you can just hook up each sub to each channel for a "stereo" effect.
Old 12-07-2004, 03:08 PM   #5 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
Run your subs in Series for an 8 ohm load, that is all you can do, unless you want to invest on some new subs or amp
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
