What do the wire colors stand for? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2004, 06:35 PM   #1 (permalink)
View blabedyblah's Photo Gallery
I have the dash in my 1991 Corolla taken apart and the stock radio out, but I can't figure out which wire goes to what. The cd player that I have to put in has a color diagram on it, so I know what the wires on it are for. Its just that theres no diagram on the stock one. Can anyone tell me which color goes to what in my car please. Im going crazy without music.
blabedyblah is offline   Reply With Quote
Old 12-11-2004, 06:42 PM   #2 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Did you cut the factory plug ?? (you should not !!!. ///// Buy Metra adaptors) Makes it easy.
metraonline.com
If you cut the plugs either put them back and buy adaptors or check out.
installdr.com
CraigW is offline   Reply With Quote
Old 12-11-2004, 06:43 PM   #3 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
Battery/Memory..............Blue/Yellow
Ignition/Accessory..............Gray
Ground............................Brown
Power Antenna..............Black/Red Pink/Blue
Amp Turn On.................N/A
Illuminator....................Green
Dimmer............................N/A
Speakers
FR+..............Light Green
FR-...............Blue
FL+..............Pink
FL-...............Purple
RR+..............Red
RR-...............White
RL+..............Black
RL-...............Yellow
S2B_Blown_3.5 is offline   Reply With Quote
Old 12-11-2004, 07:18 PM   #4 (permalink)
The wires dont match up.
Heres what colors I have coming out of the dash:
Black
Yellow
White with Green Stripes
White
Red
Speakers
Green
Blue and Yellow Striped
Brown
Purple
Blue
Pink
Green
Old 12-12-2004, 09:10 AM   #5 (permalink)
Some of the colors you have are shown as 1983-86 wiring ?? www.installdr.com Toyota Radio Wire Harnesses
Old 12-14-2004, 01:11 AM   #6 (permalink)
Gameroom cash: $133100
View profuse007's Photo Gallery
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
courtesy of www.the12volt.com
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 12-17-2004, 10:03 PM   #7 (permalink)
View anuthaCamry's Photo Gallery
don't cut the blue wire, whatever you do, do not cut the blue one!!! ....or was it the red one, i don't know!
I didn't use a metra adapter either, I used a scosche. But really adapters are the way to go, mine was only $5 at sears.
anuthaCamry is offline   Reply With Quote
