small yet powerfull amplifiers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2004, 11:33 AM   #1 (permalink)
View 96toyot100's Photo Gallery
does anyone know of a couple good amplifiers that are at least 1000watt but are really small? i need to put one under my seat and i dont have that much space for it.
96toyot100 is offline   Reply With Quote
Old 12-18-2004, 11:38 AM   #2 (permalink)
View OHWJaJae's Photo Gallery
Memphis makes a small 1500 I believe. Not sure how hot it gets, especially for 1500w under a seat. I'll think about it.
OHWJaJae is offline   Reply With Quote
Old 12-18-2004, 12:25 PM   #3 (permalink)
Do you know how much room you have? Memphis makes the smallest amp of that size that I can think of, but you might be able to fit another amp in there if you can let me know how much room you have. Don't forget, the amp needs to vent, so you don't want to cram an amp under your seat. Heat rises and the seat will just trap it all. This is no good for the amp.
Old 12-18-2004, 04:25 PM   #4 (permalink)
i got about a foot front to back, and side to side and about 2 inches of thickness....yeh i accounted for the heat, that would give it room to breathe, plus i would have a small fan blowing across it.
Old 12-18-2004, 04:37 PM   #5 (permalink)
The Memphis 1000D is 16.5"l x 6.5"w x 2"h
I think their older line is even smaller, but slightly higher. I'm trying to think dude, hopefully someone else will find this thread and save me.
Old 12-18-2004, 04:41 PM   #6 (permalink)
is it 1 or 2 channels? i dont know if i need 2 channels to run 2 subs...or could i just run the 2 subs off 1 channel? they are 4 ohm xplods...thanks for your help
Old 12-18-2004, 04:45 PM   #7 (permalink)
waiiit. shit dude.
What model subs do you have? I assumed you were looking for a 1000RMS @ 1 ohm.
Give me the model number on your subs.
Old 12-18-2004, 06:11 PM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You can run them off 1 channel, but the subs have to be wired in series or parallel.
Series = 8 ohms.
Parallel = 2 ohms.
Another option is to use a 2 channel amp and run one sub on each channel.
"Skoolin' the unlearned!"
Old 12-18-2004, 06:25 PM   #9 (permalink)
Series = 8 ohms.
Parallel = 2 ohms.
I didn't want to tell him anything because I'm not sure if he really knows what impedance his subs are. A lot of people don't know the difference between single and dual voice coils. And I'm guessing he has 2 500watt max Sony subs. Shit I fucked up. Shoulda asked from the start.
Sorry for the confusion 96toyot100.
Old 12-19-2004, 10:26 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
Thats true.
My explanation above is for 4 ohm svc (single voice coil) subs.
DVC gets a little more complicated.
Old 12-19-2004, 12:05 PM   #11 (permalink)
2 sony xplod, 1100 watt 12" subs at 4 ohms XS-L1237. how would i run the 2 subs in series or parallel? i just know how to plug one sub into one channel and the other into another channel.
Old 12-19-2004, 04:35 PM   #12 (permalink)
Ok dude, your sub is SVC 4 ohm and Sony claims it can handle 300RMS. Problem with that figure is that it's overrated. If you go with a sony amp you can send it what they claim to be 300RMS, but if you buy an amp that isn't overrated you'll be overpowering your speakers. This may not be a bad thing if you're experienced, but it could be depending on the amp.
You need an amp that can put out roughly 500-600RMS into 2 ohm or a two-channel amp that can put out 250-300RMS @ 4ohm per channel.
Since you didn't spend a lot on your subs I'd recommend a low end amp such as kenwood, pioneer, HiFonics, etc.
Some amps to look into (I'll update as I find more):
HiFonics ZX6400 ... might be a bit expensive
HiFonics BX1000D... still might a bit too expensive.
Old 12-20-2004, 02:33 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
Series
1. Take the positive off sub #1 and wire it to negative of sub #2.
2. The negative terminal on sub #1 and the positive terminal on sub #2 get wired to the amp. In other words the 2 terminals that are left over get wired to the amp.
Parallel
1. Positive on sub #1 to positive on sub #2.
2. Negative on sub #1 to negative on sub #2.
http://www.jlaudio.com/tutorials/wir...dex.html#2svcp
Old 12-20-2004, 03:50 PM   #14 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
Run your subs in parallel, this will give you a 2 ohm load, your can easily run a JL 500/1 or if you want better go with a DLS A3 amp, easy to hook up for under the seat installs.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
