If it's all the speakers, then it probably means you wire that one speaker ok. I think it's spelled soldering by the way. Does the headunit still work? If not, then check the fuse. If that's not the problem, check the wires out of the Headunit maybe.... Seems weird that they worked fine for about an hour and then just stopped working. Did you do anything at the point where they stopped working? Like touching wires, changing the volume, or anything else like that?
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
