97 corolla rear speaker removal/installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2004, 02:20 PM   #1 (permalink)
View MickeyMouse's Photo Gallery
i just bought new rear speakers for my 97 corolla and i cant seem to find a way to remove the stock ones. any help would be greatly appreciated. thanks
MickeyMouse is offline   Reply With Quote
Old 12-25-2004, 10:38 PM   #2 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Look in a Haynes repair manual. Can be found at your local library, or buy one for $15.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 12-25-2004, 10:53 PM   #3 (permalink)
Street-Cruiser
Ostornadoe's Avatar
View Ostornadoe's Photo Gallery
Just got a Haynes Repair Manual today, so I'll tell you what it says.
"Using a trim panel removal tool, carefully pry the retainers loose and remove the pillar trim panels from each end of the rear package tray. Pry the retaining clips loose and remove the cover from the high-mounted brake light. Remove the mounting bolts, disconnect the electrical connector and remove the brake light assembly. Remove the rear seat headrests(if equipped). Pry the retainers loose, remove the bolts(if equipped) and remove the package tray. Remove the push-nuts and separate the speaker grilles from the package tray. Disconnect the electrical connectors, remove the mounting bolts and remove the speakers from the package tray. Installation is the reverse of removal" (There were no pictures for the 1997 and lower models)
Hope that helped... Putting the book to use already. Thanks for the excuse to use it
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
Ostornadoe is offline   Reply With Quote
Old 12-30-2004, 11:28 AM   #4 (permalink)
Ghostridin the whip
Ah those things are a total bitch. I was doing that yesterday and damn I broke quite a few of those plastic retainer shits. When removing the brake light cover, PUSH IN on the retainers, and then pop them out.
