96 avalon hardwiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2004, 09:15 PM   #1 (permalink)
View Redboi926's Photo Gallery
I know its bad to hard wire the stock wires to my head unit, but it seems like there are no harness' on the market that sells it. So i unplugged the two plugs from the factory amp, I noticed there are 2 brown wires and 2 white with blue stripe wires, what are these? It seems I cant find the power and ground wires too. Someone please help me out!!!!!! thx...........
Redboi926 is offline   Reply With Quote
Old 12-28-2004, 11:10 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Oh but there is a harness. Goto Circuit City, though should have it.
Metra Toyota/Lexus Premium Amplifier Vehicle Harness (70-8112)
http://www.circuitcity.com/ssm/Metra...oductDetail.do.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 12-29-2004, 07:09 AM   #3 (permalink)
Gameroom cash: $133100
View profuse007's Photo Gallery
METRA kit info
1995-1999 Toyota Avalon
Premium Kit N/A
Budget Kit 88-00-8000
Harness Into Car 70-1761
Harness Into Factory Radio 71-1761
Amplifier Integration 70-8112
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 12-29-2004, 08:10 PM   #4 (permalink)
Hi everyone I just bought it and it still doesnt fit the harness. Is it because I have the premium 6spkr system? Does that have anything to do with it? Seems like this is the most confusing radio installation I have ever come upon to....Please give me feedback on what to do Thanks
Old 12-31-2004, 06:18 PM   #5 (permalink)
View gouki64's Photo Gallery
1995 Avalon XLS with Premium Speaker System
Hey Redboi,
If your stock system is anything like mine... the 15/16 pin Premium sound adapter should work as posted here in this forum. I have a stock 7 speaker premium factory sound system in my 1995 avalon XLS. It consists of two front tweaters, two front speakers, two rear speakers, and a rear deck mounted subwoofer with an external factory amp under the glove box.
The premium adapter is a female plug. I unplugged the 2 connectors from the factory stereo and one of them plugged directly into the sound adapter.
Take a look at this adapter: (this was what i used)
http://www.autotoys.com/x/catalog/TO...SS_p_1334.html
and look at your factory wiring harness.
When the rain stops, ill try to snap pics.
gouki64 is offline   Reply With Quote
Old 12-31-2004, 11:21 PM   #6 (permalink)
TTORA Hawaii Member
View amber00dak's Photo Gallery
not sure if this will help, but its all i got. i dont know if the power wires i listed are the same as those with the premium sound systems. good luck
Constant 12V+ -----Blue/Yellow
Switched 12V+ ------Gray
Ground --------------Brown
Illumination --------Green
Antenna Trigger ----Black/Red
Left Front (+) -------Pink
Left Front (-) -------Purple
Right Front (+) -----Light Green
Right Front (-) ------Blue
Left Rear (+) -------Black
Left Rear (-) --------Yellow
Right Rear (+) -----Red
Right Rear (-) ------White
amber00dak is offline   Reply With Quote
Old 12-31-2004, 11:31 PM   #7 (permalink)
From the Premium Metra Sound Adapter Wiring Harness:
You will use the Front Preout and Rear Preout from your new aftermarket stereo (The Metra Premium wiring harness has RCA cables that will plug right into your after market deck preouts).
Color:------ Function
Gray ------- Right Front
White ------ Left Front
Purple ------ Right Rear
Green ------ Left Rear
All thats left from the Metra Premium Harness is:
Color: ------ Fuction:
Black-------- Ground
Yellow------- Battery/Memory
Red---------- Ignition/ACC
Blue---------- Power Antenna
Blue White--- Amplifier Turn on Remote Wire
Hook these badboys up to the wires coming out of your aftermarket deck and youre good to go. It's still raining over here... so pics will have to wait.
Old 01-02-2005, 12:18 AM   #8 (permalink)
TTORA Hawaii Member
if the Metra harness he got wont fit, how will this help? those arent the factory colors, they are the colors that the harness uses to match with the colors aftermarket decks usually use
Old 04-16-2007, 12:17 PM   #9 (permalink)
View muchachomalo's Photo Gallery
Be sure to specifically ask for the toyota premium sound package. THe same thing happened to me. I got it and it was the wrong one the correct one has the pre-amp connectors.
muchachomalo is offline   Reply With Quote
Old 04-16-2007, 07:57 PM   #10 (permalink)
Gameroom cash: $117630
View gideon1331's Photo Gallery
Even when you find an adapter that might fit that Avalon, there is no wiring harness meant for use in that car.
a) All avalons came with an external amp, even the most basic factory system had a 170 watt amp. Therefore there is no bypass circuit as there is in any Toyota that has a stereo option with no external amp.
b) The wires running from the factory headunit to the amp are of a very high gauge, and therefore cannot handle the output of an aftermarket headunit without severly reducing sound quality and the risk of fire. In fact, the factory wires are shielded, because they are designed to carry such a low current.
The ONLY way to do it properly is to splice into the wires on the output side of the amplifier which is up under the glove box. And yes, it is a pain to do.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
