Best Remote Starter w/good range for Toyota? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2004, 11:08 PM   #1 (permalink)
View bjwerti's Photo Gallery
I have a 2004 Sienna XLE, and would like to install a remote starter (& alarm if only available in a combo unit). I see a lot of these remote starter/alarms with 2-way communication, FM vs. AM transmission, etc. And then I need to determine who can interface well with the Toyota factory wiring & security on the XLE model. My dealer told me that I would need to buy an alarm bypass module & use the valet key for the Toyota Factory security bypass. Any advice? Thanks.
bjwerti is offline   Reply With Quote
Old 12-28-2004, 11:11 PM   #2 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
take it to a car audio place, they sell high end remote starts/alarms i think they will be more helpfull
Porkch0p220 is offline   Reply With Quote
Old 12-28-2004, 11:21 PM   #3 (permalink)
View virtualkuz's Photo Gallery
If you want a remote start in your sienna you are going to have to give up a key. In order for your ECU to let the engine start it needs the transponder key in the system. If you hook up a remote start you effectively bypass the pretty useful and secure transponder system. As for actual brands I would go with DEI and their Viper brand. Another thing that may affect you is if you lease your sienna. You would be hacking up all kinds of wiring if you install a remote start and when you turn it in when the lease is up they may hit you with all kinds of fees, like a new wiring harness. Its probably cold up there in MN but personally I don't think remote starts are worth it.
2005 Corolla XRS Silver Streak Mica
2005 Kawasaki Z750S Candy Plasma Blue
1993 Kawasaki EX500a Luminous Polaris Blue
virtualkuz is offline   Reply With Quote
Old 12-29-2004, 02:45 AM   #4 (permalink)
Resident slacker
kgasso's Avatar
View kgasso's Photo Gallery
For what it's worth, my Clifford has a module that was programmed with the transponder key information, and is activated when the remote start is activated.
kgasso is offline   Reply With Quote
Old 12-29-2004, 06:55 AM   #5 (permalink)
Gameroom cash: $133100
View profuse007's Photo Gallery
if you want something affordable and decent, get autopage rs-855LCD alarm/keyless/RStarter
bypass unit: 555U or 556U (same as 555U, newer model)- require a spare key
as for installation, check out www.the12volt.com they can help you w/ it. ive seen several 03 04 sienna has been on to get some help.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 12-29-2004, 01:02 PM   #6 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
I love my compustar alarm/starter combo
www.compustar.org
you can go anywhere from 1500 ft of range to 6000 ft of range, one way or two way.....and they can use a modual instead of a spare key.
also you can make the aux outputs do whatever you want.....for example, on my 4runner i have it so it will roll down or up my rear window, and on my camry i have it so one button will turn on my lights, and the other button will turn on my underbody kit..
alex is offline   Reply With Quote
Old 12-29-2004, 02:26 PM   #7 (permalink)
compustar is far the best ive seen but they cost the most(LCD, 2way). 04 sienna, they dont have a bypass available right now that dont use a spare key.
99-03 sienna be able to use 555U (spare key require) or 555F (no spare key require to give up)
Originally Posted by alex
www.compustar.org
Old 12-30-2004, 03:43 AM   #8 (permalink)
View baggedcamry's Photo Gallery
yeah id go with DEI or CodeAlarm....and id go with a U, there a little more dependable...id also try to go with something that has 2 way....that way u know when ur car is started...its too damn hard trying to hit the buttons right
baggedcamry is offline   Reply With Quote
