2004 RAV4 Sub Installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2004, 03:47 PM   #1 (permalink)
View CrashTest's Photo Gallery
I'm installing a powered sub (Clarion SRV303) in an '04 RAV4. It's 120W max (10A fused), so I was planning on just tapping into the power outlet wire running from the drivers kick-panel to the rear outlet. Anyone know the color-code for this wire??
Also, the sub uses an amp controller connection and I believe the RAV4 system doesn't have an output for amp control. What should I hook this wire to?
Thanks,
Steve
CrashTest is offline   Reply With Quote
Old 01-02-2005, 05:33 PM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
You should always use a separate power wire straight from the battery especially for something powerful such as a subwoofer.
And you're better off getting a new headunit that has RCA sub out. Stock headunits don't have extra connections for a sub and you're simply looking more headaches.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 01-02-2005, 09:27 PM   #3 (permalink)
Luc
View Luc's Photo Gallery
Correct, always run a separate fused power cable, never use the stock one and assume that will be enough, you'll end up popping fuses. You can get a high-to-low converter to tap into the speaker wires to feed the amp if it only takes RCA (low) level.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
