Are you wanting a store bought band pass look but custom built, in your spare tire compartment, or built into your side molding??
Reason why I ask, if you are artistic you should be able to come up with a descent box for two 12's that will still allow you to access your spare tire area. I do not have pics of mine but I have two 12" L7's built into seperate custom boxes. I tore out all of my side moldings and dynomatted everything that I could. Then I cut access panels in the moldings so that I could mount my amp with a see thru plexi screen. Placed a blue neon inside for the look. the panel was cut part of the way down the wheel well interior molding toward the bumper on the left side. Then I cut access panels in the moldings right behind the back seat so that I could slide my box into the molding hiding the actual size. I dynomatted the inside of the moldings themselves and boxed off the access panels making sleeves for the sub boxes to slide into. I have 1.6 cft per sub ported out of the side facing each other. If you can visualize what I mean?? I have about 11" between the two boxes so that if I just have to fold my 60 split down to fit something in my trunk I still can. I used beige carpet I bought from Crutchfield. I also bought my ports and wire terminals there for pretty cheap. Looks pretty good.
Don't have pics but after all that I guess I need to take some as I barely understand it myself now.LOL
Free Gen 2 Camry book for anyone coming through Louisville, KY
