radio wires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2005, 01:55 PM   #1 (permalink)
View jimek's Photo Gallery
radio wires
ok i have a dark blue wire from my radio the radio says its the remote on
and from my 97 camry i have everything hooked up but there are two wires extra from the car. they are a white with a green stripe and a dark green wire. and my radio is a dual radio that is only working half way. the eject button works. the whole thing is not illuminated and i cant get any sound sources to work. please help. thanks.
jimek is offline   Reply With Quote
Old 01-09-2005, 05:06 PM   #2 (permalink)
View JohnCWms27's Photo Gallery
in the Sticky threads there should be a website that shows you what those two wires are - the "remote on" wire can be hooked up to the remote turn-on wire of an external amp so that way the amp shuts off when the car shuts off
'94 Camry LE
JohnCWms27 is offline   Reply With Quote
Old 01-09-2005, 10:38 PM   #3 (permalink)
Luc
View Luc's Photo Gallery
Did you use a harness adapter or did you splice it? If you didn't use an adapter, spend the extra $15. For Gen4 and newer, there is NO antenna turn on lead since it's either a non-automatic or in-glass.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
