two subs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2005, 05:54 PM   #1 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
two subs?
I just bought a 250 watt amp for two 300 watt subs. Its is a bazooka .. model: CSA150.1 . I was wondering if i can wire two subs to this amp b/c in the installation manual it shows only wiring one sub.
i wish i knew more about sound .. please help.
vsixcamry is offline   Reply With Quote
Old 01-09-2005, 11:54 AM   #2 (permalink)
toyota tuner
vsixcamry's Avatar
im thinkin a new amp... tx for your help
Old 01-09-2005, 05:02 PM   #3 (permalink)
View JohnCWms27's Photo Gallery
is the amp 250 Peak or RMS? and are the subs 300W Peak or RMS? If the subs are 300Watts Peak, then 150 watts to each subs is probably near its continuous power range. like 'thoughthard' said, you can wire them in parallel.
'94 Camry LE
JohnCWms27 is offline   Reply With Quote
Old 01-09-2005, 05:21 PM   #4 (permalink)
toyota tuner
vsixcamry's Avatar
k, so it may work i think im gonna wire it and so if the sound is good, one last question, how do i parallel the wiriing. Thanks in advance.
Old 01-09-2005, 05:23 PM   #5 (permalink)
toyota tuner
vsixcamry's Avatar
o and the subs are 300 Watts peak, but i will get half the power to each sub meaning 75 watts, im not willing to go 75 watts.
Old 01-09-2005, 09:54 PM   #6 (permalink)
what is the continuous (RMS) wattage for the subs - do you know?
thats a good diagram there - if you wire it up like that (in parallel) you will send 250 watts (peak, of course) to each sub...in other words the amp will act as if theres only each sub, so instead of each sub getting 125 watts, they will each get the full 250 peak
'94 Camry LE
Old 01-09-2005, 10:10 PM   #7 (permalink)
if they were wired in series the subs would split the power, but wired in parallel the subs should not split the power - each sub will get just as much power as if it were the only sub on the amp.
'94 Camry LE
Old 01-09-2005, 10:52 PM   #8 (permalink)
cam2Xrunner's Avatar
Originally Posted by thoughthard
The subs will split the power, regardless of parallel or series wiring.
If you have only one speaker, that speaker is carrying the entire power
of the circuit. However, if you have more than one speaker, the load is divided between them. If both speakers have the same resistance (ie, it is equally hard to push
power through them) then each will take half the power.
Correct.
What kind of subs are they. You will probably get better results by going with only one of them at 150 watts RMS
