Balanced Inputs and Line Drivers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2005, 07:27 PM   #1 (permalink)
Wazzaaap!
View mauibuilt59's Photo Gallery
What is the purpose of balanced inputs? I have an xtant amp and it has balanced inputs. Is it just something that I already have? or is there something special that I have to buy or do to utilize it?
Also, are line drivers worth the extra 100 bucks? Is there a noticable difference in clarity and volume from a 2V output and an 8V output?
92 Camry v6 (3vz-fe)
mauibuilt59 is offline   Reply With Quote
Old 01-10-2005, 09:29 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
Balanced line typically can accept/carry a higher signal level through the wires. Their signal integrity is "balanced" in the sense that they act as differential pairs that work through a transformer so that noise is minimized. RCA are considered unbalanced since they're more of low level carrier and are easily affected by noise, even with good shielding. You may need an adapter from Xtant to take a balanced input from an unbalanced source.
Line drivers may be useful if you have an amp that can take the higher voltage input. Otherwise, there's no need for it.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 01-10-2005, 09:39 PM   #3 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
excellent explanation Luc, most preamp eq and crossover units have line drivers built into them, so if you have a 2V preout HU and your amp can accept 4-8V invest in an EQ
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 01-10-2005, 09:51 PM   #4 (permalink)
Wazzaaap!
i have an alpine 7892 which has a 2V preout. I also have an alpine eq, which has a 4V preout. My xtant says it can accept a balanced signal of 17V and an unbalanced signal of 8.5V. The amp also has a switch where you can switch the balanced input on and off. I thought you needed a different type of wire (other than rca's) to use the balanced input, but there is no other type of connection on the amp itself. you can check out the users manual at page 6 of http://www.xtant.com/html/techSuppor...02_4004Man.pdf
How would I use the "balanced input" function and would it be worth it to buy a line driver that can boost the signal up to 17V?
Old 01-10-2005, 10:19 PM   #5 (permalink)
Got SQ?
eddiem67's Avatar
you can use the rca, some manufactures like zapco, make there own balanced design, but you can use the same rca cable, the signal is just fed to the amp differently...well...balanced
Gen 4 V6
