subs are sliding - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2005, 11:48 PM   #1 (permalink)
View ProjectCorolla's Photo Gallery
subs are sliding
i gotta deal for 300 bucks for two 12s -they gave me xplods but said if im not satisfied i can exchange them for memphis kickers audiobahn or mtx no charge- and a box etc they mounted the amp behind the sub so the sub was like pushed up towards the front of the trunk so i unmounted the amp and moved the subs back figuring the weight would keep them in place while driving. turns out i was wrong. the subs seem to be sliding foward and to the right no matter how careful i drive. do i mount the box or what?
ProjectCorolla is offline   Reply With Quote
Old 01-16-2005, 12:22 AM   #2 (permalink)
A Poor College Student
The Wolf's Avatar
View The Wolf's Photo Gallery
You could tie down the box in the trunk, or fit a piece of wood to the floor and attach brackets to the box and floor. I had that problem and was using a piece of wood in the opening for the back seats/trunk as an amp rack. Took my box and 2 extra piece of metal, drilled holes, and no more moving box.
"Your in violation of signature rule #4."
Crap.... guess I'll change it later.
The Wolf is offline   Reply With Quote
Old 01-16-2005, 01:07 AM   #3 (permalink)
cam2Xrunner's Avatar
I'd trade them in for some kickers if possible. Xplods would be the last choice out of those brands.
Old 01-16-2005, 01:09 AM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Trade up to kickers...
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-16-2005, 03:01 AM   #5 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
i would trade to kickers, i love kicker, but for your box problem, what i did with my twelve was to drill some hooks into my trunk walls and use bungee cord, check out my car domain for pics
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 01-16-2005, 11:05 AM   #6 (permalink)
Street-Cruiser
Ostornadoe's Avatar
View Ostornadoe's Photo Gallery
First trade up the subs. The xplods are the worst ones out of those you mentioned. Then make some 90 degree brackets and stick them in there.
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
Ostornadoe is offline   Reply With Quote
Old 01-16-2005, 11:19 AM   #7 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
To hold down my boxes I used a cargo net from my trooper and just got some hooks and strapped that bitch down.
http://www.xclusive.bz
Old 01-16-2005, 11:55 AM   #8 (permalink)
Originally Posted by thoughthard
Use some of that "no-slip", under the rug, material under you sub box. In my Paseo, my sub would float around my trunk. I put a layer of that under the trunk mat, and the problem is gone. The box does not move on the carpet mat itself.
where can i get this?
Old 01-16-2005, 12:01 PM   #9 (permalink)
as for trading the xplods for kickers i might cause my friend has 2 memphis 12s and i put my xplods up against his and mine hit way harder and get this i have the stock head unit still with no preamps so i had to use an adapter. and from what i understand memphis is one of the top brands right under kickers so im pretty satisfied with the xplods. especially with the price.
Old 01-16-2005, 01:59 PM   #10 (permalink)
Get the kickers, you will be much happier, trust us. BTW which model Xplods are you running and which model Kickers are available for trade?
Old 01-16-2005, 03:05 PM   #11 (permalink)
TTORA Hawaii Member
View amber00dak's Photo Gallery
first off, trading the subs really wont make much of a difference. its all gonna sound like boomy crap with that bandpass box your using. get a sealed or ported box if you want some decent sounding bass. what models for each sub are they offering you for trade?
the easiest mounting solution without getting crazy is to go to a hardware store and get some of those metal corner protectors. the ones that are used to keep wooden cabinets (like speakers, etc.) from getting the corners all beat up and splintered. just mount them to the trunk floor so that the corners of the sub box fit down into them and it will keep it from sliding backwards. it will be sandwiched between the rear seat back and the corner mounts. and if you need to, you can take the box out pretty easy by lifting it up over the corners protectors otherwise, just make some L brackets and attach on side to the box and the other to the trunk floor
amber00dak is offline   Reply With Quote
Old 01-16-2005, 03:06 PM   #12 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Sony is garbage. I'd get kickers out of those brands too, but I wouldn't be using a bandpass box. Sealed or ported only, depending on what you're trying to do.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 01-16-2005, 03:50 PM   #13 (permalink)
whats the difference between bandpass, sealed, and ported boxes?
Old 01-16-2005, 03:55 PM   #14 (permalink)
Bandpass is what you have, it's typically louder but usually sounds like crap. Sealed is just that, sealed, no vent or ports. Sealed is typically better for sound quality, accuracy, tight bass. Ported uses either tubed ports or sloted vents. Ported is typically louder and still retains alot of sound quality.
sealed
Slot ported
Old 01-16-2005, 03:57 PM   #15 (permalink)
Street-Cruiser
Ostornadoe's Avatar
Do a search, people have talked about the differences before. But basically, sealed sounds the best IMO
Just get creative and you can figure out a way to stop the box from sliding.
