Amplifier mounting recommendations for 2001 Camry LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2005, 10:14 AM   #1 (permalink)
View cpowell100's Photo Gallery
Question Amplifier mounting recommendations for 2001 Camry LE
I have a Clarion amp that I will have professionally installed today (bought it from Crutchfield) and want to hear from owners that have had an similarly-sized amp installed in the trunk of a Camry LE (same model year or, if different, roughly the same trunk layout). The amp is about 11" x 13".
Three questions:
1) If mounted in the trunk, what is the best way to mount the amp, i.e., somewhere on the sides of the trunk with the fins oriented vertically OR laying flat in a corner area? The former is preferred but I can't find an area that looks like it is well suited for it, i.e., I don't see any flat surfaces that would handle the 11" x 13" "footprint". The latter would be easy but is less desireable since it takes up valuable trunk space.
2) If I had it mounted vertically, wouldn't it be necessary to have the installer use some kind of special hardware/platform to hold the unit?
3) Is mounting the unit under the seat as good (maybe even the preferred) option?
Thanks for any advise you can give.
Chris
cpowell100 is offline   Reply With Quote
Old 01-18-2005, 10:20 AM   #2 (permalink)
View .tony. .riot.'s Photo Gallery
I would mount it the rear part of the backseat. You'll only need a few screws.
.tony. .riot. is offline   Reply With Quote
Old 01-18-2005, 10:21 AM   #3 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I mounted my amp under my seat. That isn't too good if you have a cheap amp that gets hot quickly and need lots of breathing room, but it does save you on the lenght of power wire you need. I like it better when mounted somewhere else though. In my trooper I have it mounted on the back of the seat. I screwed on the amp to to pieces of compressed wood, so it looks somewat like a helicopter (if you get the picture). Then I mounted the compressed wood onto the seat.
http://www.xclusive.bz
Old 01-18-2005, 01:08 PM   #4 (permalink)
Wink '01 amp mounting recommendations...
Thanks for your recommendations. I will consult with the installer to figure out which approach works best.
Chris
Old 02-12-2005, 02:30 PM   #5 (permalink)
View hdub86's Photo Gallery
Put it on the back seat, that is where mine is.
hdub86 is offline   Reply With Quote
