need help for toyota camry 2002 front speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2005, 01:10 AM   #1 (permalink)
View butho33's Photo Gallery
i need help for my toyota camry 2002 front speakers .... it has the JBL 6 disc changer and 8 speakers ... iv learnt that my front speakers are 6x9 ... i was thinking if iv change it to 6.5 , would it be better and would it fit in the front ? and also does my car have an amp ?
butho33 is offline   Reply With Quote
Old 01-21-2005, 01:27 AM   #2 (permalink)
View cbrjay's Photo Gallery
If you decide to go with 6.5's, i would recommend getting a component system. There's more work involved to fit the 6.5's, but it would be worth it if you went with components. If I remember correctly, your JBL amp is located in the glovebox? The master installers can help you out on here.
2005 Yamaha Raven R6
2003 Honda CBR954RR
2000 Honda Accord Coupe
1997 Toyota Camry- 153,000mi.,still running strong!
DRINK TEQUILA!!!
cbrjay is offline   Reply With Quote
Old 01-21-2005, 03:35 AM   #3 (permalink)
cam2Xrunner's Avatar
You're thinking the right way to go with 6.5" Components are definitely the way to go. Get some MDF woof and make a mounting trim. What are your plans for the system, do you want to go all out or are you looking for a simple upgrade? Do you plan on changing out your headunit? If you're going to go with components you're going to also want to get a good amp to send them plenty of power.
Old 01-21-2005, 12:40 PM   #4 (permalink)
thanks for your help ... i wanna do the sound system on my own ... but im having problems taking out the wirings n stuff .... i need a guide from the internet or something ? is there any online guide for camry 2002 ? i wanna recreate the whole system.... planning on changing the amp , speakers and probably a small sub
Old 01-21-2005, 03:47 PM   #5 (permalink)
You don't need to remove all the wiring from the factory system, just bypass it.
Use a harness like this one
http://www.cardomain.com/item/SCOTA02B?vq_id=none
for your power, ground, dim, and accessories. Then Run a set of TWISTED Rca's to the amp. I stress the word twisted because those help to prevent alternator whine, or any other noise that can interfere.
From the amp run 16 gauge speaker wire.
Check out www.knukonceptz.com for all your wiring needs.
