Car Stereo Install Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2005, 08:22 PM   #1 (permalink)
NRM
NRM's Avatar
View NRM's Photo Gallery
Little help from anyone here please.
I just installed a Sony CDX-M8805X. I've never done an install before, but it was pretty straightforward. I did the harness and then I did the plug and play. Afterwards, it powered up and worked properly, my music was even playing. So I get out of the car to clean up and when I get back in, the unit face was off. I couldn't turn it back on, but the open close and eject cd buttons all worked. The face just wouldn't turn on, nor the unit. I checked fuses, they all seemed in order.
I figured it was the line that turns the unit on when the ignition is on. I'll check that later.
But the shady part is that I tried hooking my stock stereo back up and that didn't turn on either. A little worried now, but I'm hoping any of you could help me out a bit.
NRM is offline   Reply With Quote
Old 01-22-2005, 08:42 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Yeah its probably the ignition wire since it would need constant and ground to open and close and what not.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 01-22-2005, 09:23 PM   #3 (permalink)
NRM
NRM's Avatar
Jeez, alright, so I changed it up so that the deck has constant power so I just have to turn it off manually every time I get out, but NOW...
my clock does not work when I turn my car on and my AC on switch doesn't work either. I figure it has something to do with the ignition wire, but all other lights work, fresh outside air AND the rear defoggers.
Any ideas anyone?
Old 01-22-2005, 09:30 PM   #4 (permalink)
Motorcyle Tech
Racer_Rodney's Avatar
View Racer_Rodney's Photo Gallery
Any ideas anyone?
there is a fuse blown, check the cig lighter, its prolly out too.
I did that one too instaling my deck
CarDomain pics-->http://members.cardomain.com/racer_rodney
My WebSite------>http://rcarman.home.mchsi.com/
Racer_Rodney is offline   Reply With Quote
Old 01-22-2005, 09:47 PM   #5 (permalink)
cam2Xrunner's Avatar
Did you forget to disconnect the neg. on the battery?
Old 01-22-2005, 09:49 PM   #6 (permalink)
NRM
NRM's Avatar
No, I disconnected and only reconnected after everything was plugged in. And after that it worked for that two or so minutes.
It's nice that I hear a fuse might be blown. I drive an 05 Corolla, do you have any idea which fuse it might be?
Old 01-22-2005, 09:52 PM   #7 (permalink)
NRM
NRM's Avatar
You were right about the cig lighter, it might just be a blown fuse afterall.
Do you think that if I put in a new fuse, the ignition wire to my deck would work? My deck is stupid so I have to open it and press the source button to turn it on everytime.
Thanks man.
Old 01-22-2005, 09:56 PM   #8 (permalink)
Motorcyle Tech
not sure about the locations of the fuses but in my 01 it was one in the drivers compartment just left of the steering wheel. it will tell you which fuse in the owners manual
Old 01-22-2005, 10:12 PM   #9 (permalink)
Luc
View Luc's Photo Gallery
Did you connect the illumination wire from the deck to the dimmer wire on the harness by mistake? That could short out the clock and cigarette light. If not, perhaps that wire from the harness adapter is touching metal somewhere behind the radio.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 01-22-2005, 11:45 PM   #10 (permalink)
NRM
NRM's Avatar
Hey guys, I got it.
It was a fuse and it turns out there was a back page to the fuse diagrams that I missed. I checked all the ones labeled radio first. Either way, I found the blown one and got it replaced. Then I redid the wiring work and in the meanwhile cut myself pretty badly with my knife when I was opening a box of new connectors.
Either way, thanks a bunch to everybody. I almost felt like bringing it in to get it checked out because of this. Thanks.
Old 01-22-2005, 11:48 PM   #11 (permalink)
Motorcyle Tech
Hey guys, I got it.
cut finger ...lol
