Ok. Yes I'm a big dumbass. I took off my high pass filter (which was set to 100hz) cause tech support told me it was okay to at moderate volume and blew one of my Infinity Kappa 42.5i's in the front. So, I need new 4" speakers because one of them sounds like shit now.
I have Kappa 63.5i's in the back, so I'm thinking of getting 42.5i's again for the front. Plus I have all the wiring set up for them (they have external crossovers).
Then again. The 42.5i's had a min frequency of 75Hz, and I think I blew them because when the high pass filter was turned off, the frequency went to low.
I'm considering getting
these Kenwoods as they have lower frequency range (all the way down to 45Hz) so maybe with them I can keep my high pass filter off. (can I?)
Also I'm considering getting
these Kickers for the same reason.
Also, both the Kenwoods and Kickers have lower RMS than the Infinitys, so maybe that would go better with my system, since I am running only off 22x4 RMS (50x4 max) headunit power.
Would you take the Inifintys, Kickers, or the Kenwoods??
I would really want to get the Infinitys, as I'd only have to change one speaker and the crossovers for them are already wired, but if the other speakers are better sounding/more reliable, I will get them.
What else can you guys recommend? ($60 or lower on ebay)
note: I know I won't get bass out of 4" speakers, but the reason I want lower frequency rating is so they won't blow if I take my high pass filter off. I would like to take it off to get more bass in the back from the 63.5i's.
