05 Camry Dashkit... choosing which one? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2005, 08:58 AM   #1 (permalink)
View Sonnie's Photo Gallery
We installed a headunit in our 05 Camry yesterday using what I suppose is the standard dashkit. Not sure who makes it...
We used the trimring with the kit because the headunit trimring would not snap in place properly.
The problem is that it doesn't fit flush with the dash. It has about 1/16" lip around the bottom side of the kit.
I know there is another dashkit made by Scosche...
Anyone tried either kit with one being better than the other?
Thanks!
Sonnie is offline   Reply With Quote
Old 01-27-2005, 09:14 AM   #2 (permalink)
View 04sev6camry's Photo Gallery
i think i have the one that on the top. it pretty good but it doesnt sit right in the dash, ive tried movin it around but the panel with the airvents is still offcenter
04sev6camry is offline   Reply With Quote
Old 02-11-2005, 01:06 AM   #3 (permalink)
pcboy123's Avatar
View pcboy123's Photo Gallery
thats an 02 dash kit
http://www.tune-town.com/faceplate/2002_Toyota_Camry_faceplate.htm
Currently Have
04' Camry SE V6
With Factory Bodykit
pcboy123 is offline   Reply With Quote
Old 02-11-2005, 01:08 AM   #4 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
iTrader Score: 7 reviews
View xpeed's Photo Gallery
It's 02 for sure. 05's are rounder.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 02-11-2005, 01:10 AM   #5 (permalink)
pcboy123's Avatar
and this other one is stated as 02 and up
http://www.scosche.com/scosche.aspx?...B&CategoryID=5
im currently looking for one my self for my 04 camry se
Currently Have
04' Camry SE V6
Old 02-11-2005, 08:07 AM   #6 (permalink)
We were able to drill the holes out a little larger for the bottom mounts so that when we pressed on the bottom it would allow the mount to slide down a tad... while holding it flush against the dash, tighten down the mount good. I probably need a pic to describe what I'm trying to say.
This only works with the mount in the top picture. Those two tabs on the bottom... the holes where the screw fastens to the dash need to be higher up on the tab. If you press on the bottom part of the mount to get it flush, you will see that the holes for the screws do not line up.
Sound Domain shows that bottom picture as the kit for the 04 and 05. It will probably fit 02-05.
SONNIE
Cedar Creek Cinema
