Here ya go.
12volts white + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Power Lock blue/black - passenger kick
Power Unlock blue/red - passenger kick
Notes: Green/white on models with factory alarm.
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ green dimmer switch or kick
Parking Lights- lt. green or white steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger red/white or black - plug at top of fusebox
Notes: Use the Black in a 2 pin connector at the top of the fusebox on versions without a sunroof. On cars with a sunroof use the red/white in a 4 or 6 pin connector in the same location. When adding dome light supervision use the door trigger wire and relay isolate to keep ground from entering the fusebox side of the wire or unlock will not function properly.
Dome Supervision
Trunk/Hatch Pin red/white - light or pin in trunk
Notes: On the wagon version the rear door is tied in with the door trigger wire.
Hood Pin red - anti-theft ECU
Notes: The anti-theft ECU is located high in the drivers side kick panel.
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer black ac check connector
Horn Trigger green/red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
