Peel n Seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2005, 01:24 PM   #1 (permalink)
View Beamonesque's Photo Gallery
Peel n Seal
I just purchased some rolls from Lowe's. The only kind they had was the 6" by 25 ft. Anyways I layered the trunk lid and it has stopped rattling considerably, but my problem area is the trunk around the brake lights and license plate. It still rattles loudly. Am I going to have to take apart that area and apply the peel n seel inside? I will post pictures later today so you can see what exactly I'm talkin about.
'90 camry le
Beamonesque is offline   Reply With Quote
Old 01-29-2005, 09:40 PM   #2 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
wat type of car u got i got a 98 and i had alot of problem where the taillights are i bought some insolation fabric its like cotton but it comes in yellow or pink go to the insolation section at lowes and u will see these bags filled of this thing u put it in the opeinng where the taillights are and u can also buy more press n seel were the linsence plate is but put it from the outside of the trunk not the inside so it looks like ur peel n seel is ur linsence plate
lucanhookup is offline   Reply With Quote
Old 01-30-2005, 12:42 AM   #3 (permalink)
i have gen 2. 1990 camry le. Its the tail light section thats I can't seem to stop the rattle in. Its difficult to attempt to put any peel n seel in the nooks and crannys behind the taillight back there...
'90 camry le
Old 01-30-2005, 04:19 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You have to remove the trunk lining.
As for the license plate. Remove it, lay down a few strips of that peel n seal, then screw the license plate back on. The peel n seal will fill in the gap between the license plate and car.
"Skoolin' the unlearned!"
Old 01-30-2005, 03:51 PM   #5 (permalink)
Its the part of the light that is connected to the trunk lid. You know when the trunk raises up? Right around the license plate area. There is no trunk lining there, its just metal and the wires running through. Maybe I should get some sort of filler foam? Oh and yea I've taken care of the license plate rattle itself.
'90 camry le
Old 01-31-2005, 06:19 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
My mistake. I thought you were talking about the lights in the trunk.
Apply the peel n seal directly to the metal.
Maybe unbolt the lights from the trunk lid, if it makes it easier.
