sub in sidepanel? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2005, 12:10 PM   #1 (permalink)
View 96toyot100's Photo Gallery
Question sub in sidepanel wise or stupid
if i were to put a sub in my side panel in the back of my truck under the quarter window, would i need to have a box behind the panel or could i use my truck as a sub box?
96toyot100 is offline   Reply With Quote
Old 02-01-2005, 04:27 AM   #2 (permalink)
cam2Xrunner's Avatar
The best way to do this due to the limited amount of space is to build a sealed enclosure out of fiberglass.
Old 02-01-2005, 04:33 AM   #3 (permalink)
You could also do a free air setup, but probably won't sound nearly as good as a sealed enclosure. If you do decide to go with a freeair sub make sure you use alot of sound deadening in that area(well also if you do a sealed).
But look into raammat60 or eDead
www.raamaudio.com
www.edesignaudio.com
Old 02-02-2005, 02:01 PM   #4 (permalink)
would dynomat seal off that area or just help with sound and vibrations? where would i get some dyno, how much would i need, and how i would i seal it all off?
Old 02-02-2005, 04:26 PM   #5 (permalink)
It won't seal off the area but it will help to stop any ratting that may occur after mounting a sub there. Don't waste your money on dynamat. Go for the eDead that i linked above.
The best way to do what you want to do is fiberglass, due to the limited space.
Old 02-02-2005, 08:20 PM   #6 (permalink)
what about expanding foam? fiberglass seems too technical
Old 02-02-2005, 08:55 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Expanding foam is good for filling gaps. Thats about it.
Fiberglass is the way to go.
"Skoolin' the unlearned!"
Old 02-03-2005, 07:01 PM   #8 (permalink)
i found a cheaper solution today, i cut the hole with a dremel then wired the sub and mounted it....it works pretty good i just cant crank it up or they will cut out which is ok, at least i have some bass for now till i get the $$$ for the edead stuff. thanks for yallz help
