Not sure if this will help you or not but when I had my 99 camry xle, there was an additional harness that was already wired for the non-external amp system. I just pulled out the oe cd player and set aside the harnesss that it was using and used the other harness that was there for my Pioneer cd player. But all of this not might be applicable to your avalon so
Also when installing my flip out pioneer after the old pioneer cd player, I just removed the external amp and just hardwired the whole system. I ran a power wire from the battery to the cdplayer and put a small in line fuse near the battery. Just match the same size fuse that is in your alpine cd player.
For the Acc turn on lead I tapped into the ciggarette lighter lead. I ran a ground wire from the cd player under the steering column and found an existing grounding point. Route some RCA's from the cd player under the center console, under the carpeting, or you can go alongside the door sill. Make sure to run the RCA's from the deck on the opposite side of the car asthe power wire for your amps.
From the amps use 14-16 ga, use 99.9% oxygen free copper speaker wires to the front and rear speakers.
I hope some of this helps.
