2005 Toyota Camry XLE CD/ tape player - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2005, 09:47 PM   #1 (permalink)
Whatanexperience
View peterlola's Photo Gallery
USA 2005 Toyota Camry XLE CD/ tape player
I am thinking about updating my LE model with a CD/ Tape player coming from the XLE
model. Can the 2005 Toyota Camry XLE CD/ tape player be adapted to the LE 4 cylinder model.
The wiring In the Camry LE is different from the XLE Model and won't fit the plugs of the XLE
Player. The dealer is even suggesting a new harness ($1500). A friend of mine is suggesting getting an amp but which one. I would appreciate any input.
peterlola is offline   Reply With Quote
Old 02-03-2005, 10:36 PM   #2 (permalink)
cam2Xrunner's Avatar
I can show you some links that will build you a killer sound system for 1500 dollars. Don't waste your money on factory stuff, the JBL system isn't even that much better than the stock CD player.
Old 02-05-2005, 02:46 AM   #3 (permalink)
Whatanexperience
I have already bought the Unit that comes on the XLE and I want to use it on my Le Model. Where I live, They won't break into a car to steal a factory sytem. That is my main concern
Old 02-05-2005, 03:09 AM   #4 (permalink)
You would need either the factrory amp or an aftermarket amp. that CD player doesn't have an internal amp.
Sounds like a pain in the ass.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Look into the JL Clean Sweep
http://www.jlaudio.com/press/CleanSweep05.html
That might work well in this situation to go between the CD player and the amp. This is the route I would go and get some good aftermarket amps.
Did the CD player have any wiring that came with it?
Old 02-05-2005, 04:08 PM   #5 (permalink)
Luc
View Luc's Photo Gallery
You might as well ebay that XLE unit, since you will need the OEM amp, and ALL of the wiring harnesses between the preamp deck and OEM amp. Should've done your homework first before an impulsive purchase.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 02-05-2005, 10:29 PM   #6 (permalink)
Whatanexperience
JBL Clean Sweep may be the anwser to my problem. Thanks
Old 02-05-2005, 11:42 PM   #7 (permalink)
That will work good even for the reg headunit that you have.
Another way you can go if you want to keep it with a factory look is by using the factory cd player as the "decoy" Leave that one there, an in that space under the AC controls on your camry, You might have space to mount a Din Sized headunit, maybe even double din monitor headunit(if you want to go that far).
Same idea as this.
http://www.raamaudio.com/fanaticmechanic2.htm
Old 02-05-2005, 11:54 PM   #8 (permalink)
View anuthaCamry's Photo Gallery
you should not have to pay 1500 dollars to get it to work,
they will rob you at the dealership if you let them (edited)
anuthaCamry is offline   Reply With Quote
Old 02-06-2005, 01:10 PM   #9 (permalink)
Whatanexperience
What's a din sized Headunit? and what does it look like?
Old 02-06-2005, 01:14 PM   #10 (permalink)
Whatanexperience
I wanted to upload the pic of the front and back of the unit I am talking about, But I couldn't. Does anyone know how to upload Pics? Thanks
Old 02-06-2005, 07:46 PM   #11 (permalink)
Luc
Even if you get the CleanSweep, you still need matching harness that goes to back of the XLE unit. How else would you feed the signals to CS? It's easy to buy all the equipment, but it's useless when you don't have all the wiring.
If you want to post pictures, you have upload them to a hosting service, then link the pictures with [img]URL here[/img] format.
Old 02-07-2005, 10:46 PM   #12 (permalink)
Whatanexperience
Good point luc. Thanks
Old 02-09-2005, 01:07 PM   #13 (permalink)
View ModPod's Photo Gallery
People still use tapes
ModPod is offline   Reply With Quote
Old 02-12-2005, 10:56 PM   #14 (permalink)
Whatanexperience
If you Have a Ipod or any Mp3 player, you can listen to it in your car through a tape adapter. The tape adapter gives a better sound and clarity and the wireless tuner.
Old 05-18-2005, 04:03 PM   #15 (permalink)
View JLTD's Photo Gallery
I'd like to point out that JBL has nothing to do with CleanSweep. It's a product offering from JL Audio.
JLTD is offline   Reply With Quote
