93' camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2005, 02:11 PM   #1 (permalink)
View 93' camry's Photo Gallery
93' camry amp install
I recently purchased 400 watt amp to power my 2 10" fosgates. I also still have my factory deck. Would it be easier (but more expesive) to just buy a new deck rather than wire all my speaker wires to a power converter or the RCA cables? If i bought a cheap one from wal-mart (around $50) would this do for what i need to hook up my amp?
Thanks for any feedback,
marc
93' camry is offline   Reply With Quote
Old 02-04-2005, 05:19 PM   #2 (permalink)
cam2Xrunner's Avatar
It would be eaier and cheaper to install a line ouput convertor than to install a cd player.
This would work for you.
http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-85
If you can spend a 100 or so you can get a decent entry level pioneer cd player. Ebay is pretty cheap.
Old 02-05-2005, 09:21 AM   #3 (permalink)
so this device just plugs right in to the old factory deck? and after plugging it in the RCA cables just plug in to that. I already purchased a speaker level converter. It requires me to cut all the speaker cables and reroute them to the converter then it has rca outputs.
Old 02-05-2005, 03:16 PM   #4 (permalink)
That is a speaker level convertor, you tap into the speaker wire.
Which one did you get? Got a link?
Since you are using it for the subs just tap into ONE of the rear speaker wires, you don't need to do all 4.
Old 02-06-2005, 11:53 AM   #5 (permalink)
i got one at walmart for $15. What is a link?
Old 02-06-2005, 12:21 PM   #6 (permalink)
Nevermind. I meant link as in a link to a web page. Good luck with the install.
Basic Amp Install Instructions
That might help you with ?'s on installing the amp.
Old 02-07-2005, 02:24 PM   #7 (permalink)
can i use wire coming from the 2 rear speakers and connect that to the converter? Also where could i find a 12v in the back seat/ trunk area? I want to try and wire the amp without taking hte deck out if possible.
Old 02-07-2005, 07:04 PM   #8 (permalink)
Yes you can use the wiring from the rear speakers, it's not important to use both rear speakers, you can use one if you want. Just make sure that if you sometimes fade your music to the left at all you will want to use the left side speaker wire. You don't need to take the deck out to power the amp for the subwoofer. You will however need at least 8 gauge power and ground wiring. For the power wire make sure you have an inline fuse shorter than 18" from the battery. A 70-80 amp fuse should be fine.
For the ground make sure you scrape away the paint to get to the bare metal wherever you ground it.
http://elitecaraudio.com/tips/car_au...pinstall.shtml
^just skip the step where you run the rca's from the headunit. In your case you run the rca from the LOC to the amp.
http://www.toyotanation.com/forum/t64154.html
Old 02-08-2005, 07:21 AM   #9 (permalink)
I already have power installed i just need to know if i can just hook up the remote wire without wiring it to the deck where the antenna wiring is. thanks for all the help so far!
Old 02-08-2005, 07:47 AM   #10 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
Tap into the rear speaker leads off of the rear deck. Not too tough, and if you need power antenna lead, you can run that off of the actual power antenna as well...prety basic.
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 02-08-2005, 12:17 PM   #11 (permalink)
For the remote wire you can wire it to the ciggarette lighter as well. I don't know about the power antenna, wouldn't that only get power when opening and closing?
Old 02-08-2005, 01:47 PM   #12 (permalink)
How would i go about connecting the remote wiring to the power antenna? If i connected the wiring i have to the antenna would'nt it take the power away from the antenna? or can i just cut splice into the antenna wiring and use half the wire for the remote wire and just keep the other half connected?
thanks,
marc
Old 02-08-2005, 07:54 PM   #13 (permalink)
well i decided to just go ahead with splicing the antenna wiring. NOT A GOOD IDEA!! Before hooking the remote wire to the amp i turned on the radio and i hear a crackling sound when i turn up the volume a little. I also noticed the right rear speaker not working but when i use the balance nob to the right side of the car then the speaker works. I dont know how splicing into the antenna wiring could do this. I have no idea what i did but its not good!
please help,
marc
Old 02-08-2005, 08:05 PM   #14 (permalink)
Use the ciggarette lighter as the source. It's easy enough to get to.
Old 02-08-2005, 08:58 PM   #15 (permalink)
how can i get to the cig. lighter wires?
