Originally Posted by parimento1
yes i would like to go with a separate woofer and tweeter money is no object on this install, I just want to get the best sound quality that i can. thanks again,
-brian
That's what I like to hear.
Well the stuff I'm going to recomend is pretty expensive but is of the highest quality. I could name off some other incredibly expensive stuff but it won't sound much better than this.
Since your avalon has a spot for a 4" midrange, I would recomend utilizing that and going with a 3 way component speaker system. You will have to have kickpods made to house the 6.5": midbass.
Check out the
DLS Iridium 6.3
You're going to want to send these components at least 150 watts RMS to each side.
The DLS A3 is an excelent Sound Quality 2 Channel amp.
The Zapco
750.2 is an awesome amp. A little more pricey though.
For the rears just take out the speakers. Run no speakers, unlesss you want to do a surround sound system for a DVD player/screen, then get some decent coaxials.
For the Sub check out the Image Dynamics IDMAX 12"
http://www.imagedynamicsusa.com/webs...cts/IDMAX.html
Match it with the DLS A6 amp.
You're also going to want to sound dampen the car if going with this setup.
http://www.toyotanation.com/forum/t64909.html
