steering wheel control and aftermarket deck? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2005, 02:52 PM   #1 (permalink)
View photikfusion's Photo Gallery
is it possible to get an aftermarket deck and still use the audio steering wheel controls on gen 5.5 camrys?
photikfusion is offline   Reply With Quote
Old 02-10-2005, 02:55 PM   #2 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
yes and no, it depends on the deck, some of them have a remote control input and if it does then you can usually buy some type of interface module for this.
Hatch is offline   Reply With Quote
Old 02-10-2005, 03:39 PM   #3 (permalink)
i c.. so if this deck had the remonte control input, and i buy that interface module, i would just basically be connecting wires which means i could then be able to use the audio steering wheel controls, correct?
Old 02-10-2005, 09:49 PM   #4 (permalink)
Luc
View Luc's Photo Gallery
It's possible as long as you have the wireless remote to the aftermarket radio. There is a device called the SWIX that can tap into the resistance wire(s) in the steering column for the audio controls, then feed it back to a module that you have to program, and feed it through a IR transmitter that you mount in the line-of-sight so the headunit's IR receiver can accept it.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 02-10-2005, 11:11 PM   #5 (permalink)
cam2Xrunner's Avatar
Hey Luk do you have a link for that? I'm going to need that in the future. Thanks
Old 02-11-2005, 12:41 AM   #6 (permalink)
yeah thanks for the replies you two. has anyone on this board done it before? to any steering wheel mounted controls.
Old 02-11-2005, 08:42 PM   #7 (permalink)
Luc
Here ya go. It's actually SWI-X. I've done a few before and works pretty nice. Again, for the optimal location for the IR transmitter, install it in the line-of-sight. But I've seen it work just as well right under the aftermarket radio with a 1/8" hole through a dash kit that gets hot-glued inside behind.
Old 02-19-2005, 11:17 AM   #8 (permalink)
View flipmo's Photo Gallery
I had mine installed at mobile one for $90. Wasn't bad, i guess.
flipmo is offline   Reply With Quote
Old 02-21-2005, 08:33 AM   #9 (permalink)
rippin it up camry spd
View S13/R32's Photo Gallery
its hard to find wired remotes on head units these days but some of the sony head units came out with wired remotes, and with a bit of stuffin around u could connectit to the steering controls or use the controls that came with it and somehow put them in ur steering wheel if ya got a plain old one
S13/R32 is offline   Reply With Quote
