what size wiring for my amp? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2005, 10:28 PM   #1 (permalink)
View PimpinInAvalon's Photo Gallery
i have the alpine 500x1 V12 amp i was wondering what size power wire i would need for it, and what size ground... it is gonna be running with my alpine type r 12's and my alpine HU
Sig removed. Violation of rule #8.
No advertising.
PimpinInAvalon is offline   Reply With Quote
Old 02-10-2005, 11:14 PM   #2 (permalink)
cam2Xrunner's Avatar
4 gauge would be about right. Do you have another amp for the mids and highs? Or are you running the speakers off the headunit?
Old 02-11-2005, 06:58 AM   #3 (permalink)
off the hu for power of mids and highs...may uprade later on...
No advertising.
Old 02-11-2005, 02:29 PM   #4 (permalink)
If you're going to upgrade to a high power amp for the mids and highs you might want to run 0/1 ga power wire so you won't have to upgrade later. If you're going for a Smaller amp for the mids and highs then the 4 ga. will probably be enough for both amps, use a distribution block of course.
Old 02-11-2005, 02:48 PM   #5 (permalink)
not yet toy owner
View snipe523's Photo Gallery
4ga will do ya good like said. If you plan on adding another amp for your speakers later that is going to be anywhere above 300W or so than I would go a little bigger with the wire.
99 Hyundai Sonata (I know I know, I am planning on buying my taco in a few months)
::Pioneer 8600, eD Nine.2, eD eDi 6500's, Avionixx AXT800.2, eD 12K sub
snipe523 is offline   Reply With Quote
Old 02-11-2005, 03:21 PM   #6 (permalink)
Gameroom cash: $147537
As big as you can use.
Old 02-11-2005, 04:02 PM   #7 (permalink)
but too big is also bad from what i heard...
No advertising.
Old 02-12-2005, 01:54 AM   #8 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
4 guage can hold up ~1000 watts or so, its still an over kill for that small amp.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 02-12-2005, 02:04 AM   #9 (permalink)
View anuthaCamry's Photo Gallery
how can it be too bad? as long as your amp can put out at least one/tenth of one single watt I doubt you would lose ANY power from using a larger wire!! I've ran 1/0, 4, 6, 8 on systems and the bigger the wire the better. You can even measure how much power is lost through your wiring by attaching a fast acting volt-meter between the batt+ and your amp+. If you use 1/0 guage and are putting out 3,4,500 watts or so you would only lose 0.10-0.20 volts or so, however if you were using like 8, or even 10 guage then you could be losing over 1 volt or more...
anuthaCamry is offline   Reply With Quote
Old 02-12-2005, 12:41 PM   #10 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
electricity will follow the path of least resistance so adding more paths does nothing detremental.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 02-12-2005, 02:02 PM   #11 (permalink)
just go w/ the 4guage, no need to get the giant 0guage.... period.
future is future, he prolly wont upgrade to anthoer system for wnother yrs.
