Typically, you can just disconnect the brain and your car will still run. However, to be safe, just disconnect all the connections that run to the car from the brain. You'll have to reconnect the starter wire that should've been severed to wire in the starter kill relay; the starter wire should be black/white. But first, find the brain, and follow along all the wires to where it connect, and disconnect. Make sure you tape off any exposed wires.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
