sub enclosure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2005, 10:02 AM   #1 (permalink)
View 96toyot100's Photo Gallery
Question sub enclosure
i put one 10" sub in each of my side panels on my t100....i can hear the bass, but since its a free air system, it doesnt hit as hard as i want it. what would be the easiest way to seal the subs in the quarter panel without using fiberglass?
96toyot100 is offline   Reply With Quote
Old 03-02-2005, 01:36 PM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
well why did u make it a free air system anyways is the question u should be asking yourself.. if u wanted it to be loud u would ahve just put it in a sealed or ported box. but not to be mean..
i really dont have any idea how you would seal them without fiberglass.. but im sure someone will know the answer
Corollacrazy42 is offline   Reply With Quote
Old 03-05-2005, 02:38 PM   #3 (permalink)
View GSteg's Photo Gallery
the chest hitting thump that you're looking for is usually found within the peaks of midbass frequencies.
In an Infinite Baffle install, you lose the upper end response.
1992 Acura Legend LS
-auto
-4 door
-stock
GSteg is offline   Reply With Quote
Old 03-06-2005, 08:55 AM   #4 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
i have no idea what a t100 is but either way you'll have some problems with sealing your sub enclosure. u can try some silicone based sealant but that only provides a tight airspace, for how long i cant say. the other issue is that the actual volume behind there might be too much or too little. oh and one more issue, if your side panel has some flex in it then the tonal quality and tightness wont be what you're after.
Cheers
Huy
1989 BEAMS 3S-GE SV21 Camry
da_horse is offline   Reply With Quote
Old 03-06-2005, 03:37 PM   #5 (permalink)
well im going to have to bite the bullet and pull off the side panel and build the box to the truck piece by piece....its going to take about a day to do one box but it should be worth it. the sub wont be mounted to the panel, i'll have to cut away some more panel and have it be flush. thanks for everyones advice!
