So i am gonna get a new 95 cam hopefully in not too long... i am planning out what i want to do for my trunk stereo set-up and i just wanted to get your opinions and such on troubles you think i will run into and how you think it will look...
please excuse my shxtty drawings in paint (5 min.)
OK so the top pic is how it will look in the blueprints, the bottom pic is what you will see from the open trunk view
the yellow is my yellow top - already trunk mounted
the pink is my solobaric s12l5 sub (600 RMS hold)
the green is my amp kicker kx600.1 (700+ watts rms birth sheet)
the tan is a stinger 1.0 farad cap (blue leds, add a little flava)
the light blue are neon lights, placed throughout the trunk and set up
the dark blue lines is the plexi glass screen over the setup in the wheel well
the red/grey are the power and ground wires (4 gauge)
the maroon are 12V fans, one on each side of the amp in the wheel well to move some air
ok so this is what i want to do, take out the spare wheel and place my amp down there, in a simple open box with my cap, and run all the wires under a wood floor i will lay down in the trunk, or maybe some carpet...
then i will have a plexiglass sheet to see the amp and cap, and then to hide the wires and edges of the amp, it will only show about 90% of the amp
i figure i can just tap the fans into the remote lead of the amp, since they have such small draw they would not hurt anything, and then they are on when the amp is on
in the pic i did not show speaker or RCA wires... those are kinda no duh
my only realy questions are these...
-will the 2 fans in the wheel well give me adaquate venting/airflow
-can i ground the amp and cap to the metal in the wheel well? Where else on the body would be better/worse
-do you like the styles? It is basic, with some flare, the car is my DD so i want to be able to still use my trunk, but look nice and have it for shows also, the spare wheel is not a big issue since i have AAA and buddies around who could help me out in a pinch
thanks!
