Amp Fuse Location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2005, 09:17 PM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
Amp Fuse Location
Does it matter where the inline fuse is located on the power wire from the battery to the amp? like a specific distance or such?
WhiteRabbit is offline   Reply With Quote
Old 03-03-2005, 09:28 PM   #2 (permalink)
View thoughthard's Photo Gallery
Within 12" from the battery, I think.
thoughthard is offline   Reply With Quote
Old 03-03-2005, 09:46 PM   #3 (permalink)
TN's furry friend
^whats the reasoning?
Old 03-03-2005, 10:32 PM   #4 (permalink)
nicoj122
Guest
Posts: n/a
View nicoj122's Photo Gallery
not to fry the cable. trust me 12" or less from the battery. you could burn your car down
Old 03-03-2005, 10:58 PM   #5 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
yeah the closer the better, the whole point of the fuse is to act before the surge can get very far
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 03-04-2005, 12:02 AM   #6 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
the reason i figure the fuse has to be so close to the battery is because of the possibility of a accidental ground, which would be bad in case you didnt know. Your amp is already protected from surges with the onboard fuses, but if you put your fuse closer to the amp and your power wire is grounded somehow towards the center or front of the car, this usually doesnt happen if you are very careful, they bad things will happen to your battery. If your fuse is close to the battery then this is provented.
me personally i have my will have my fused distribution block in the trunk because i will display it. You just have to be careful.
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 03-04-2005, 02:02 AM   #7 (permalink)
Even in the case of DrtySthV6SE's fused distro block, I would still fuse the power wire close the battery. I dunno if DrtySthV6SE was stating that he uses no fuse close to the battery since the distro block is fused.
Old 03-04-2005, 02:15 AM   #8 (permalink)
TN Ass Man
yes you assumed right, i usually dont have one close to the batt and have been doing it like that for 4 years now, might not be the smartest thing but ehhh, whatever, i like to live dangerously
Old 03-04-2005, 05:59 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Thats not very smart.
You need a fuse or circuit breaker after the battery. Within 18" of the battery.
Your fuse/distro box is for the amps.
In my setup I have a circuit breaker after the battery. Which runs into a fuse/distro box for my 1 of my amps and processors. My other amp has a 100A ANL fuse + holder which branches off the fuse/distro box.
"Skoolin' the unlearned!"
Old 03-04-2005, 10:10 AM   #10 (permalink)
TN's furry friend
dang, i dont feel like moving my fuse from the trunk back to under the hood. i moved it cause i put my intake in and originally had the fuse rest on the stock airbox and didnt want the fuse to dangle around...
is it that critical?
Old 03-04-2005, 10:19 AM   #11 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
^ Yes it's EXTREMELY critical to move it back. The whole point of having the fuse is to have it close to the battery.
You guys are nuts not to do this...I wouldn't even drive around if my car wasn't wired up like this.
Silver Streak is offline   Reply With Quote
Old 03-04-2005, 10:41 AM   #12 (permalink)
TN's furry friend
guess i need to bust out the crimper when i get home then
Old 03-04-2005, 04:40 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
^ Don't forget that your amp(s) need to be fused too.
Some amps have built on fuse(s). And some don't.
If your amp(s) don't have built on fuse(s) you need to fuse them externally.
Old 03-04-2005, 08:41 PM   #14 (permalink)
TN's furry friend
^yea it has a built on fuse, youre talking about the fuse that sticks to the side right?
Old 03-05-2005, 04:11 AM   #15 (permalink)
Grenaded piston
88 LE's Avatar
^ Built on fuse meaning the fuse plugs into the amp.
