GEN 5 CREW: Instructions on running 4ga. wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2005, 11:27 PM   #1 (permalink)
View 1200mk's Photo Gallery
how did you guys run it from the hood? is there a hole in the firewalll? could someone tell me where they ran the rcas as well as the 4ga?
thanks!
1200mk is offline   Reply With Quote
Old 03-08-2005, 11:36 PM   #2 (permalink)
Unrecognized
DMDrew812's Avatar
View DMDrew812's Photo Gallery
Snake-grabber tools are amazing for that. I got through an MR2's firewall by fishing through some bundle-cover, and it worked fine. Try not to poke holes in nothin though.
DMDrew812 is offline   Reply With Quote
Old 03-08-2005, 11:54 PM   #3 (permalink)
where do you buy a snake grabber?
Old 03-09-2005, 02:01 AM   #4 (permalink)
whats the best way to hook up the + wire to the battery?
Old 03-09-2005, 02:09 AM   #5 (permalink)
-VIPStyleCars-
mcv30's Avatar
View mcv30's Photo Gallery
i paid a friend to do all the wiring setup for me
but from what i remember vaguely...
he ran the wires through the firewall like you said its really close tuck inside; he mention "near the steering column under the hood there is a hole"
i don't know if that is a correct name, but the wiring all looks good to me
mcv30 is offline   Reply With Quote
Old 03-09-2005, 02:29 AM   #6 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
carry a fire extinguisher?
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 03-09-2005, 02:34 AM   #7 (permalink)
hmm...
i looked in my hood and the rubber gromet seems like i might be able to sqeeze some wire through there.... not sure if that is the proper procedure.
I have another question.... theres a red cap on my battery how do i remove that? does it just come right off?
Old 03-09-2005, 11:48 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
If you remove the front drivers side fender/wheel well liner, there should be a grommet against the firewall. Of course you have to jack up that corner of the car and remove the tire first.
My power wire runs down the drivers side of the car. RCAs on the passenger side of the car.
Never run the 2 together, as you could get interference (emi) radiating into the rcas from the power wire.
Cheapest way to go about it, is to use a 4 ga. crimp on ring terminal. Crimp the ring terminal onto the end of the wire, then connect it to + (positive) post of the battery.
I would crimp and solder the terminal. If you don't have a big enough crimper, you can use a vise, or phillips screw driver and a hammer.
The other option is to buy a aftermarket battery terminal. You can buy one from a car stereo shop for around $20.
"Skoolin' the unlearned!"
Old 03-09-2005, 01:53 PM   #9 (permalink)
Fixing My Jet
View Meperezs's Photo Gallery
If you look under the hood to the left of the stirring colum they have a rubber gasket lookin thing. I ran mine though there. You can also see it from under the dash. They have shit already goin though it so it isnt that hard to just fit it in or cut a small hole in it.
If you can read this thank a teacher. If you can read this in English thank an Airman.
Meperezs is online now   Reply With Quote
Old 03-09-2005, 04:28 PM   #10 (permalink)
do you just pushed it in?
Old 03-09-2005, 04:35 PM   #11 (permalink)
Unrecognized
DMDrew812's Avatar
Thats where the snaky thing comes in, if you have one. Either that or like a coat hanger, so you know exactly where its coming out, and just tie to and pull through
Old 03-09-2005, 06:07 PM   #12 (permalink)
i looked at that hole and it seems like the factory put some type of glue or seal up the hole in the gromet.
Old 03-09-2005, 07:07 PM   #13 (permalink)
tried to do it under the tire well... i found the gromat but theres not area in the hood to goto the tire well.... it looks like i might have to drill.
i looked at the rubber gromat next to the steering colum i was wondering if i should cut a hole through the rubber thing and feed my wire through there. Not even sure if itll fit.
Is drilling a hole my best option?
thanks
Old 03-09-2005, 07:50 PM   #14 (permalink)
any help?? i wanna get this hooked up asap... thanks again..
Old 03-09-2005, 10:17 PM   #15 (permalink)
-VIPStyleCars-
mcv30's Avatar
if you still haven't solved it yet...
i'll try to do my best to take a picture tomorrow if i can and post it up here so you can see where the wire went...
if i don't have the picture available tomorrow; i apologize because of busyness and other priorities got in the way, but i'll do the best if i can...
but from wiring going from under the hood to inside the interior... that's the difficult part because i didn't catch what they did to my car, only to the part where they hid the wires under the door sills and went all the way back to my trunk.
