Where to run wires? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2005, 12:40 AM   #1 (permalink)
1996 Corolla DX
View KidComa's Photo Gallery
Canada Where to run wires?
Hi, I just bought a 1996 Corolla yesterday. I just installed a new deck, and I want to put an amp and sub in the back. I'm just curious to know the best way to run the power from the battery to the trunk, and the remote/rca cables from the deck to the trunk. I'm guessing I should go under the carpet somehow? If so, how do I get the wires under there? Any other options?
thanks
Chris
KidComa is offline   Reply With Quote
Old 03-14-2005, 10:58 AM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Under the door sills. They should come up very easily, just pull up on them.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 03-14-2005, 11:57 AM   #3 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
that is where i ran my stereo wires also... power down the left side, RCA and remote lead down the right
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 03-14-2005, 12:30 PM   #4 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
There are numerous grommets and points to run the power cable through the firewall on your car, and just like Nate said, run the power down 1 side, and the RCA's down the other...or else you get noise...damn physics. Oh, and the door sills come up mad easy, just a flat head screwdriver to start prying them up, after the first one comes up, the others are easy. Welcome to the nation
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 03-15-2005, 01:30 AM   #5 (permalink)
1996 Corolla DX
Canada
Holy Bajezus... I just finished running the wires. Sorry Knailgun, but there were definitely not "numerous grommets" in my car. I ended up having to run the power behind the driver side fender; I found a grommet behind the driver side fuse box. I was going to remove the fender entirely to get access, but figured out I could nudge the piece that surrounds the wheel well over just enough to give me some room to feed the wire through. I took a few pictures, I may post them at some point.
Everything else was pretty easy, though I did break a couple of snaps in the process. Are these pretty easy to come by? Where do I get some?
Thanks for the help everyone!
Chris
Old 03-15-2005, 07:29 AM   #6 (permalink)
Knailgun's Avatar
well, at least you got the job done. The snaps aren't too bad, everyone breaks them. you can get them cheap at either Napa, or at the toyota dealership (which isn't too outrageous).
Old 03-15-2005, 10:50 AM   #7 (permalink)
1996 Corolla DX
Canada
Cool, thanks for the info Knailgun.
